ok i got two turbo cars ready to get a tune...
both cars are pretty much alike..one has built 370 other stock 346 both have same fuel with 60# injectors
sd tune with 3 bar map sensor..
there going to a shop to get the final tune i am in know way experienced enough to even to begin to tune these cars..BUT IM learning...and want to learn how to do it. but way to much money into these cars to do something stupid
what i need to do is set up a base tune for these cars that i can fire them up so they can idel and i can drive them around the block or so to check for leaks and everything is in good working order before i load them up on the trailor and take them to get tuned..
car
1999 trans am 6 speed.
MTI built 370 iron block
6.0 heads with dual valve srpings and retainers
Cam motion cam 228-224-589-588 on a 114+2 lca
Innovative t-76 turbo
6.0 truck manifolds
custom 1st try engineering turbo system. 4 inch down pipe to dump before axel
moser 12 bolt 373 gears
sumped 98 tank
aermotive pro series pump -10 feed
60# injectors
-6 regulated return
