Results 1 to 2 of 2
Thread: Can I tune the trans behind my 01 Cummins?
    Tuner CTP Racing's Avatar
    Auburn CA
    86
    Question Can I tune the trans behind my 01 Cummins?
    Any info on if i can tune my 01 Dodge trans with a Cmmins in front of it?
    98 Camaro, LS1 built, P1SC, methanol intercooled, AFR 205 heads, 48lb injectors
    2 bar speed density setup,LC-1, TH400, 3500 stall speed, gear vendor, built 9", . Just a drag car.
    Jul 2008
    3
    Pretty much only thing you can do is add a transgo kit to it They still run of Throttle pressure cable for shift firmness and timing the Transgo kits are Great kit work good if you leave out the 1-2 accumulator spring and hog the holes out in seplaterator plate and give about 1/16th of a inch of gap on the Pressure regulator valve then they hit good in every gear.
    Trannyman
