Results 1 to 7 of 7
Thread: when will the next update be?
    Oct 2006
    8
    I've noticed that many of the tables used by bullydog, efi live and a few others are not covered by hptuners. Will there be an update that will allow us to access them, if so when? I think that a table for defueling and a way of getting more rpms would be nice because it's kind of limited. I also can't seem to find a way of changing the timing. I tried crossing a hot tune from efi live to hp and noticed that i was restricted and they are pretty much two different languages so to say. Thanks
    Oct 2006
    8
    Oh and a way of watching fuel pressure would come in very handy as well as egts and a few others that were mentioned in the thread that has been pinned to the top of the list.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Quote Originally Posted by daniel99ta
    Like what? With nearly 800 tables & parameters for LBZ/LMM calibrations there can't be that much missing
    Maybe they are just labled slighly different in our software than in theirs?
    Oct 2006
    8
    i can't find anything to where i can change the timing or after comparing a bullydog tuned truck to a stock duramax, there isn't a whole lot of difference. The fuel pressure readings and egts would be a great advantage.
    HP Tuners Support
    (foff667)
    28,268
    EGT's would need to come from an EGT probe, there is no EGT stock on these vehicles. I believe there is a fuel pressure pid already in the software. If there is a specific parameter you are unable to find in our software that you can in the other guy please point it out as I'm confident its probably already in there just under a different name than what they use
    May 2007
    307
    there is a fuel pressure PID already, egt would be cool. GM should get on that
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    Quote Originally Posted by Bill@HPTuners
    Did you guys make any head way on a trans slip pid?
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
