Results 1 to 10 of 10
Thread: .cfg files
    Tuner in Training srcracing's Avatar
    May 2008
    Boca Raton, Florida
    31
    .cfg files
    Does anyone have any .cfg files for data logging LB7 vcm.
    George Landis
    SRCRACING.COM
    [email protected]
    tuner/racer/fabricator
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    There haven't been any posted to the repository so for now you'll need to start from scratch but your more than welcome to post what you come up with either here or in the repository at the top of this section.
    May 2008
    Boca Raton, Florida
    31
    .cfg file
    Here's what I have so far... Can't get the histogram to work, axis scaling comesup on 8 & 9 but still has the text in the graph. What am I doing wrong?
    George Landis
    SRCRACING.COM
    [email protected]
    HP Tuners Support
    (foff667)
    28,273
    Hard to tell without you posting a cooresponding scanner log file .hpl
    May 2008
    Boca Raton, Florida
    31
    file
    here's a couple of data logs, I was working on MPG, so there isn't alot of rpm changes
    George Landis
    SRCRACING.COM
    [email protected]
    HP Tuners Support
    (foff667)
    28,273
    #8 doesn't work because you aren't logging main fuel rate from what I can tell.
    #9 doesn't work because you aren't logging baro, if you want it mapped against map then you'll need to find a different table to map it against or simply make a custom histogram to fit your needs. like the one below
    Making histograms is just about being logical in what you are doing, if you want to map against map then log map, if you want to log against baro you better be logging baro.
    May 2008
    Boca Raton, Florida
    31
    atest
    here's my atempt at a few histograms, see if you think these will work. I'm going to try them later today.
    2002 C-3500 duramax LB7
    OS 15094441
    TCM OS 15079907
    VIN 1GCJC33192F162789
    George Landis
    SRCRACING.COM
    [email protected]
    May 2008
    Boca Raton, Florida
    31
    latest .cfg
    I made some changes to the chart section, going to test tonight.
    George Landis
    SRCRACING.COM
    [email protected]
    May 2008
    Boca Raton, Florida
    31
    latest logs
    Here's a couple of logs from last night. I still have a few problems, 2 with my histograms, I tried to follow Bill's boost histogram but I'm still missing something, also, I have a couple of charts that aren't working. What am I missing?
    George Landis
    SRCRACING.COM
    [email protected]
    HP Tuners Support
    (foff667)
    28,273
    Quote Originally Posted by srcracing
    What are you having issues with?
    If you are referring to your #2 histogram its because you are trying to somehow map spark timing which diesels don't have spark timing
