So I was getting excited about running HPT and logging my wideband that I just installed through the EGR. I was running a scan last night without setting the correct PIDs for the wideband to log. I didn't have the EGR position V logging which I didn't know you needed to.
So after I add that to log I hook my laptop up to my car, turn the key to the On position, connect, start scanning, then I turn I start the car. This is how I've scanned every other time and it's never messed up. After a few seconds it acts like I pulled a cable and then I try to reconnect manually and "validate cable license failed" comes up. It then will not connect at all till I pull all power from the MPVI unit.
I then tried to start scanning with the car already running and it will for about 2 seconds then freezes and everything all over again. Help!
