Can Vcm Suite tune shift points different in Tow Mode and Reg Mode? This might be a stupid Q :-/ but I could not find any info in this forum ???. I get my Tuner tommorrow and I just cant wait to load it and find out! Anybody have any info on this?
2003 HD Silverado 6.0 4x4 w/Quadrasteer 36" Michelin ZXL (255/100R16) (9.00R16)
Tow/Haul mode is just a fancy acronym for Performance mode which is fully adjustable
There is no replacement for displacement?&&sure there is, its called a Blower!
Hows it work? You click on Perfomance and then you are programming that section of the vcm that is active when the "Tow" button is pressed?
Yes, in various of the Transmission param sections
(esp. Shift Properties and TCC Properties) you will
see Normal, Performance, Cruise, Hot; the Performance
tables apply when Tow/Haul is active, you can edit
them the same as you can, Normal. You might set it
up like factory did for maximum clutch pressures etc.
ot you might rig it for racing, or whatever.
: Thanx Rattle and Jimmyblue. You made my day... now if only 1.5 was ready for downloading.... he he.
