I just installed everything onto my laptop by following the directions I received in my email, but it keeps saying invalid. What's next?
2002 Black on Black WS6 M6 | ASC#4489 Idle clip w/ rev
AFR/Comp | True-duals | TEXtralia | M9 w/4.30s | BMR | HP Tuners
Y2K ECSB Silverado Z-71-6" Pro Comp, 3" PA, Motive 4.88s, Moto Metals wrapped in 35" Mud Grapplers.
To download & install the newest public version 2.22 & try again.
Could you be more specific? Do I need to un-install everything before I download what you talking about? Also where is this download located? I also don't have the laptop connected to the internet, but I'm sure it's gonna have to be connected to download what your talking about, correct?
Thanks again.
www.hptuners.com
Login using your serial number & password
Download 2.22
Double click the program to run it
Click finish when its done
Open editor or scanner
copy & paste in the application key from the email you received from us
Sounds simple enough, besides the fact that the laptop I have will not connect to the internet. I've been on the phone for hrs today trying to get it to, but it won't. Is there a way to save it to a disc with my desktop, and then download it to my laptop?
Yes you can save it on your desk top and put it on a cd or flash card or usb card.Then move it to your laptop.
2018 GMC Denali A8 6.2L
2016 CTS-V
2016 C7 Z06 A8
2016 C7 Z06/Z07 A8 vert
2015 Chevy SS 6.2 LS3 A6
1996 Impala SS LT1 CAI
1995 Chevy 1500 5.3 CAI Z06 cam
1957 Chevy vert
Sure, i usually just us a usb flash drive or SD card to transfer files from my home pc to my laptop when I'm in a pinch rather than having to burn a file to a cdr or something.
Thanks guys! I'll post back when I get things going!
It still won't accept the application key. I downloaded it to my desktop, transfered it to the flash drive and to my laptop. I clicked it and installed everything, and when I open vcm editor it still says the application code is invalid. I'm lost here.
Its either one of two things:
1. you are not copying & pasting the application key in from our email & you are trying to type it in
2. you do not have 2.22 installed
Those are the only two possible reasons for this error.
Your right, I'm not using copy/paste. I've been typing it in. Why won't that work? It's impossible for me to copy/paste when the laptop HPT is on, isn't able to connect to the net. That's why I had to use a flash drive to get the update from my desktop to the laptop.Originally Posted by Bill@HPTuners
Copy and paste it into wordpad or some program and then copy and paste it into your flash drive. Then into your laptop. Then you know the drill from there.Just keep copying and pasting!
2016 CTS-V
2016 C7 Z06 A8
1957 Chevy vert
It won't work because everyone screws up when typing it in
I will try that tonight. Thanks.Originally Posted by Pro Street
I didn't, but it still didn't work...Originally Posted by Bill@HPTuners
There are only two causes for an invalid application key, if its not one its the other.Originally Posted by BriancWS6
make sure you dont get the number 0 mixed up with the letter O, thats often a problem that can been overseen
When I got in last night, I typed it in EXACTLY how it looks, all caps, dashes between the letter groups, and it worked. Thanks for everyones help along the way.
2016 CTS-V
2016 C7 Z06 A8
1957 Chevy vert
Glad it was a simple fix!
