I was tuning my VE table with my wideband, getting it a little closer each day. Then I discovered my spark table was way way too low, so I bumped it up.
Consequently, my AFR went lean to varying degrees across the board.
My question is this. If i'm tuning my VE table with the air-fuel ratio, and spark advance also affects the air fuel ratio, what do I do? Get the spark table advanced as much as I can without KR, then focus on the AFR?
thank you thank you,
D
