Originally Posted by
Ken@HPTuners
Shift adaptation:
When GM builds a trans they want the shift as smooth as possible. There are some folks who are harder on cars/trucks than others. Shift adaptation is trans learning (upper time limit).
Before shift adaptation the guys who were harder on parts burned up their clutch packs due to long shift times. Those tables help compensate for that.
They were not intended to be the main focus of shift times, only a compensation when things get ugly.
To get your shift times where you want them, you have to increase your shift pressures. Also don't forget about the Force Motor current table. On some vehicles the 100 column is set to 1245ma which will bleed off pressure.
It's safe to set the 100 column to the same value as the 96 column.
Ken
