I have tried all kinds of different settings to get the car to shift under full throttle at the desired shift points (6200). I now have the WOT shif RPM set as low as 5500 and MPH in the Normal HOT and Performance cells. And the WOT Shift Vs Speed in all those cells set as follows. 1-2 shift 35mph. 2-3 shift 80 MPH. The car still hits the rev limiter at 6500 where I have it set now. I have the desired shift time vs TQ at 0.1000 in normal and 0.0000 in performance and have tried 0.0000 in normal and it still will not shift. The car shifted fine with the preditor program that was in the car before(I did put the stock setting back in). Any ideas ?
