Results 1 to 3 of 3
Thread: going mafless  tranny ?'s
    Apr 2004
    Caseyville Illinois
    17
    was going to try to go mafless and cant figure out how the MAf ties into the transmission. I thought 98's shifted off speed and rpm. Anyone know how it ties in i had heard it has to do with load Thanks Scott
    Nov 2002
    Central Florida
    2,503
    Re: going mafless tranny ?'s
    I believe shiftpoints are just MPH, TPS, RPM but
    the transmission pressure modulation is run off
    the "torque" calculation, which probably has MAF
    (or airflow, perhaps derived off the speed-density
    mode in absence of the MAF) in there. But as to
    how the torque computation is affected... I guess
    the best bet would be to unhook the MAF, and log
    the Delivered Torque - Engine and -Transmission
    PIDs and see if you still get sane values when you
    force it into speed density operation.
    in some calibrations MAF failure will also trigger line pressure increases. This is usually earlier code.
    I count sheep in hex...
