Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 63
Thread: E40 VE Tuning using MAF Numbers
  1. #41
    Dec 2004
    Laurel, MD
    1,020
    currently we dont have a reliably coming up with the BIAS numbers, thus we we doomed to rely on the stock numbers. so you can simplify that formula to:
    GMVE=IFR*IPW*AFRwb*TEMP/MAP
    however, if what you're really after is MAF<->VE conversion, there's a formula for that in the aforementioned writeup.
  2. #42
    I'm trying this with an E40 using Tiffer's CFG from post #38. I've added a few more PIDs to the table to try and debug why the calculated GMVE is very far off from where it should be.
    When running SD only, the car would idle nearest the command AFR with the GMVE values 698 to 700.
    I performed a test where I forced the E40 into MAF only mode and completely zeroed out the SD tables, which were themselves almost spot on. Before I zeroed out the SD tables, the Mass Air Flow (SAE), Dynamic Airflow and VE Airflow all agreed. (can be seen in the from_121611 log file attached)
    When I zeroed out the SD tables, VE Airflow went to zero, as expected. Also, the GM Volumetric Efficiency PID went to zero, meaning this is derived completely from the SD table.
    I started the car and let it idle for a minute. Eventually it calmed down to where the Dynamic Airflow was in the .70 lb/min range (normal idle). And the RPM and MAP placed it in the area where it would have interpolated a GMVE near 700.
    My issue is, the custom PID BlueCat defined and Tiffer put into his config, comes up with a very different GMVE result. It should be near 700 when idling, but I see values around 2000 for GMVE. The PIDs are all set to use metric and the formula is untouched from how I D/L'd it.
    The numbers are off the same amounts even if the SD tables are not zeroed out, so zeroing them out isn't the cause.
    I also added the individual PIDs used by the custom GMVE PID. These appear to all have legitimate values.
    I'm not sure why this isn't working. My tune is scaled 50%, but that's already been factored into the MAF table, and the GMVE value is off by much more than 50%.
    maf_to_ve_test,hpl shows the results of MAF only, zeroed out SD tables, and the calculated GMVE which is far too high.
    from_121611.hpl shows the VE numbers from when the car was in SD only mode for tuning purposes. The idle areas are the ones of interest for comparing with the maf_to_ve_test log.
    2006 GTO, APS TwinTurbo, Stroked LS3 416ci, LSA heads, LS9 cam, 4L80e
  3. #43
    Dec 2004
    Laurel, MD
    1,020
    what formulas did you use? I cant see them from the logs (is there a way and i'm just missing it?)
  4. #44
    Quote Originally Posted by redhardsupra View Post
    This:
    [PID.2126.MET] / [SENS.30.MET] * [PID.2321.MET] * 1000
    Which I believe is GMVE = MAT / MAP * CYLAIR * 1000
    I've attached the CFG. Taken from Post#38, then added some pids.
  5. #45
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Use this:
    (([PID.2321]*[PID.2126])/([PID.11]))*1000
    Log Dynamic Cylinder Air, Manifold Air Temp, and Manifold Absolute Pressure (SAE).
    http://www.dsxtuning.com
    Just say no to bull s***.
  6. #46
    Use this:
    This is MUCH closer, thank you DSteck! I was able to apply this to my existing test log and get plausible values. I can't wait to try it live.
    By the way, I added .MET to the PIDs for:
    (([PID.2321.MET]*[PID.2126.MET])/([PID.11.MET]))*1000
    Prior to adding the .MET, I was getting values in the 5000 range rather than 700 range.
  7. #47
    Mar 2008
    St. Louis, MO
    4,859
    Strange. I didn't have to do that even though I run my scanner in imperial mode.
  8. #48
    I'm using Version 2.22. Perhaps that's the difference.
  9. #49
    Mar 2008
    St. Louis, MO
    4,859
    I don't care enough to revert back and see. Haha. In my table, those items are set to metric units anyway. Maybe that's why.
  10. #50
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    I apologize for bringing this back from the abyss, but I have searched and have not been able to find anything like this for a Gen III controller. Am I just not searching the correct terms?
  11. #51
    Dec 2012
    North Carolina
    119
    Mind you, I only ever tune my own Gen IV computer, so forgive me if I'm way off here.
    When I'm in VCM Scanner, there's already a "GM Volumetric Efficiency" PID under Engine->Airflow. I don't know if that comes from HP Tuners, or I have someone's custom config file. The numbers seem accurate for my car.
  12. #52
    Advanced Tuner Road's Avatar
    Dec 2014
    Terrell Tx
    478
    Tech 2 shows ve efficiency too
  13. #53
    Dec 2008
    on the Dyno
    1,825
    This back calculation cannot currently be done on a Gen3 due to not having the manifold air temp PID. IAT will work if you have the bias table disabled and temp sensor in the manifold but most people do not have it setup this way.
    Located in Central Kentucky
    ShorTuning
  14. #54
    Dec 2004
    Laurel, MD
    1,020
    Sure you can, you solve for both GMVE and the Bias curve shape at the same time. It's not easy, it's not fast, hell, it's not even deterministic, but it does work.
  15. #55
    Jun 2007
    Finland, Europe
    549
    Matlab required?
  16. #56
    Dec 2004
    Laurel, MD
    1,020
    Oh yes, with multiple toolboxes too, probably about 10k$ worth
  17. #57
    Mar 2008
    St. Louis, MO
    4,859
    MAT could be calculated in an Excel dump. If you can curve fit the bias function, you could calculate MAT within HPT using a custom PID. It wouldn't taken into account the filter, but it's all an approximation anyway.
  18. #58
    Dec 2004
    Laurel, MD
    1,020
    I'm not talking about merely calculating MAT, that's easy. I'm talking about optimizing it, simultaneously with GMVE in parametric form, for any number of dimensions too
  19. #59
    Jun 2007
    Finland, Europe
    549
    Expected that.
    I've always enjoyed your posts and comments, although I am in the the different league. I'm playing in the The Readers league, as they say.
  20. #60
    Dec 2008
    on the Dyno
    1,825
    Be easier for HP to just add the MAT PID to the scanner. I know it exists because I can log it with other software...
    ShorTuning
