Results 1 to 15 of 15
Thread: maxing out the table....
    Mar 2004
    14
    alright, helped a buddy try and sort out a problem with his car. still had stock 2.73 gearing in the program but had put in 4.10's.
    when i put in the 4.10's and the stock 26" tire, it came up with a "MAX trans scalar" error i think it was and readjusted down to a 25.7" tire. What causes this and what can i do to fix it? it's in an automatic.
    Chris
    Mar 2004
    14
    Re: maxing out the table....
    bueller?
    I think I know why but I'll wait till somebody else tries to answer..
    Business Network Solutions - for all your PC, network, printer and computer security needs.
    Mar 2004
    18
    Look like there is some sort of issue w/ this table. There is another person experiencing similar issue....
    Quote Originally Posted by z28kid98
    Chris
    Sorry, missed this one...
    What were your Engine PPM, Trans Scalar and Input PPM before the change?
    And what is the OS ID?
    I count sheep in hex...
    Mar 2004
    14
    OS ID = 9381344
    Engine PPM = 44253
    Trans Scalar = 36.8799
    Input = 7812
    That was what was listed when the stock 2.73 gearing was listed in the "previous" box and i input the 26" previous tire. then put the 4.10's and stock 26" tire give it the max engine PPM error and it adjusts to a 25.7 height. and then these values:
    engine ppm = 65535
    trans scalar = 55.2607
    input = 7812
    yeah your engine PPM is maxing out (it's trying to set to 66460, but the max is 65535), thats why the error.
    the result is that your trans should still shift at the right MPH but your cluster will be out by about 1%.
    Please email your binary to us at [email protected] and we'll see if there is any possible workaround to this issue.
    Chris...
    Mar 2004
    14
    I'm a little dumb about this, so what exactly do you need me to email you?
    Also, the friend's trans is a bit messed up. just not working correctly
    Chris
    email the .bin file please
    what do you mean the trans is messed up?
    Mar 2004
    14
    it picks and chooses whether it wants to actually engage when it shifts to 2 or 3 and never really catches in 4th.
    and about the .bin, i feel like a moron. i shoulda known that one haha i'll be emailing you the original tune that i saved. NOT the one after i changed the gearing. that way you can input the gearing and see exactly what it does.
    Chris
    Mar 2004
    14
    email was sent....
    got it, thanks.
    I also received an email from someone else, saying that other programs have a similar issue and according to them it can't be fixed. Nevertheless, i'll see if anything can be done...
    Nov 2002
    Central Florida
    2,503
    65535 (or 65536) may be a GM hard limit. Maybe your
    bud needs to go up a step in tire size just to make the
    bits happy. :P
    0xFFFF (65535) is the limit. Again, this only affects the speedo calibration, not the trans shifting. I doubt you will be able to change this without recalibrating the cluster itself.
    Mar 2004
    14
    Alright, I appreciate it!!!
    Chris
