Results 1 to 2 of 2
Thread: Torque Management
    Mar 2004
    7
    Torque Management
    Can I get a step by step way to delete TM. So far I have set the abuse torque reduction table to all zeros and I have set the torque reduction vs. torque vs. shift table to all zeros as well.
    Is this all I have to do?
    Thanks!
    Nov 2002
    Central Florida
    2,503
    Re: Torque Management
    I believe abuse torque reduction is for when you've
    done something really dumb or the trans has got its
    feelings hurt. If "normal" hard driving isn't putting you
    into Abuse mode then I would leave the "safety net".
    I also think your transmission will live longer if you
    only reduce, not zero, the torque reduction params.
    I would like to obtain understanding of the param
    basis - I've seen my EFILive logs with timing slam to
    -5 during shifts, is the table param a maximum timing
    reduction, or a modifier to the commanded torque value
    that somehow >ends up at< a spark pull? What I would
    prefer is to have about a 5- to 10-degree spark pull
    during shifts. Just need to figure out if this is something
    obvious or something you have to back into by Mystery
    Algorithm #12.
    HPTuners, do you believe the "basis" you display your
    params under is the same as in general LS1 use (i.e. are
    other-tool-users' explanations to be taken at face value
    or are there "dialect differences" from tool to tool to tool
    to be borne in mind when researching)?
