I have an 03 C5 A4. How are you guys running your widebands into the cabin of the car? Shift boot? Firewall? Somewhere in the rear? I have an LC-1.
Thanks for your advice,
Steve
Steve
I drilled hole down by interior fuse box on my 99 Vette.
So you just tucked behind the heatshield running along the tunnel and then up through the footwell?
I put mine in the stock O2 bung and ran the output to my EGR valve input on the pcm. No wires to run that way. It also simulates the narrow band.
Reb
I added a bung into the exhaust behind my X-Pipe where the H-Pipe use to be. I had no cats so I got good readings. I then drilled a hole in the right side compartment under the read deck and put the LC-1 in there. I used silicone to seal the hole.
2013 Jeep Wrangler JK
3.6 V6
More MODs than Stock
2018 Ram rebel
5.7 Hemi V8
Stock
