I have a couple of questions about this subject.
Should the AFR be in the 14.7 range when starting from a cold start?
Should the AFR be in the 14.7 range while in Open loop with the engine warm?
From what I can find, it should always be in the 14.7 range. If so, what should be adjusted to get it there. Mine is running in the 12.8 to 13.2 range till the system goens into closed loop.
I made changes to the Idle air in P/G and it does not seem to make any difference.
