Since my last thread went nowhere fast, I decided to try this out a different way. I have retuned my MAF fairly well using the open-loop method. Using the attached tune my AFR stays reasonably close to commanded AFR.
Unfortunately, with this tune I have to lower my timing a lot to prevent knock. See log for example of this.
I've been playing with this a while and I'm running out of ideas. Any help would be appreciated.
I'm starting to think that my Wideband (AFX) is to blame but from everything I've read, it should be pretty reliable. I should say that the AFR readings in the log match the displayed AFR on the AFX at all times.
Edit: I restarted from a completely stock tune and have redone the OL MAF calibration with similar results. New resulting tune and log posted.
