Hello,
I attempted to do some diagnostic work on a 98 H1 with a 6.5L turbo diesel over the weekend. When I hooked up to the vehicle to use the scanner function, the vehicle was recongized as a 2006 Hummer Alpha with a Duramax. In addition, I could only read a few parameters like ect, iat, rpm, mph and calculated engine load.
I didn't expect to be able to use the editor functions in my HP Tuner interface, but I did expect to be able to scan this application.
I'm currently running version 2.2.0. Is there some work-around that can be done? Ideally, I would need to be able to view lots of engine parameter and use some of the "on-off" functions of the scanner.
Is there anything that can be done with the current software...or are there things in the works that could get me to the end of this road?
Matt
