Thread: 1998 Hummer H1 6.5L Turbo Scanning
    Potential Tuner Bwaaaah79's Avatar
    Sep 2008
    Hello,
    I attempted to do some diagnostic work on a 98 H1 with a 6.5L turbo diesel over the weekend. When I hooked up to the vehicle to use the scanner function, the vehicle was recongized as a 2006 Hummer Alpha with a Duramax. In addition, I could only read a few parameters like ect, iat, rpm, mph and calculated engine load.
    I didn't expect to be able to use the editor functions in my HP Tuner interface, but I did expect to be able to scan this application.
    I'm currently running version 2.2.0. Is there some work-around that can be done? Ideally, I would need to be able to view lots of engine parameter and use some of the "on-off" functions of the scanner.
    Is there anything that can be done with the current software...or are there things in the works that could get me to the end of this road?
    Matt
    28,268
    Sounds like you ARE getting functionality from the scanner ie generic GM pid's, enhanced pid's are NOT supported on any pcm that is NOT supported.
    Sep 2008
    Parts of the scanner function did work. The only parameters that I could see were RPM, MPH, ECT, IAT and SAE corrected load.
    For the testing I was doing, I was hoping to be able to see MAP and PCM detected misfires.
    It's all fine though...I have access to a tech 2 to get some of the information needed for the diagnosis.
    28,268
    Yeah if its not on our supported vehicles listing and you get functionality at all with the scanner its a plus. There are many GM/Ford vehicles that you won't even be able to connect to so any scanner functionality is a good thing for unsupported vehicles.
