Hey guys looking to put some 36# L67 Injectors in my LS1. Does anyone have a corresponding pulse rate, offset chart, or anything like that from a stock tune? I have visited the repository but only found IFR tables.....
THANKS!
J
THANKS!
J
This may or may not be what you're looking for, but it's all I got. I don't use HPTuner for my vcm editing, so you have some syping ahead of you
Code:This list was created on Wednesday, September 24, 2008 by the Tiny Tuner. File Location - C:\Development\PCM_Editing\Binaries\1998_GTP_09352809.bin The Operating System ID is 9352809 and contains 440 tables. Fuel - Fuel Injector - 2 Speed Fuel Pump 00-No 01-Y 2 Speed 1 Fuel - Fuel Injector - End of Injection Pulse vs Coolant Temp Deg. BBDC Deg C -40 60.00732 -20 60.00732 0 60.00732 20 60.00732 40 60.00732 60 60.00732 80 60.00732 100 60.00732 120 60.00732 140 60.00732 Fuel - Fuel Injector - Fuel Pump High Speed Disable Flow 6 Fuel - Fuel Injector - Fuel Pump High Speed Disable Ign. Volts 12 Fuel - Fuel Injector - Fuel Pump High Speed Disable MAP 105 Fuel - Fuel Injector - Fuel Pump High Speed Enable Flow 7 Fuel - Fuel Injector - Fuel Pump High Speed Enable Ign. Volts 10 Fuel - Fuel Injector - Fuel Pump High Speed Enable MAP 125 Fuel - Fuel Injector - Fuel Pump Prime Time Seconds 30 Fuel - Fuel Injector - Injector Flow Rate 0 218.9914 10 216.499 20 213.49 30 209.3564 40 208.5053 50 208.0798 60 207.7759 70 207.4719 80 207.2288 90 206.4993 100 205.8306 Fuel - Fuel Injector - Injector Offset vs Battery Voltage 0 0 0.6534929 1 0.6534929 2 0.6534929 3 0.6534929 4 0.6534929 5 13.99691 6 4.133722 7 2.537984 8 1.808504 9 1.337381 10 1.018233 11 0.805468 12 0.6534929 13 0.5319128 14 0.4407278 15 0.3495427 16 0.2735552 17 0.1975676 18 0.1519751 19 0.09118506 20 0 21 0 22 0 23 0 24 0 25 0 26 0 Fuel - Fuel Injector - Injector Pulse Boundary Degrees 9.997559 Fuel - Fuel Injector - Injector Skew Percent 3 1 2 1 1 1 6 1 5 1 4 1 Fuel - Fuel Injector - Low Pulse Width Injector Offset vs Pulse Width vs MAP msec 0.0 0.243 0.486 0.729 0.972 1.215 1.458 1.701 1.944 2.187 2.43 2.673 2.916 3.159 3.402 3.645 3.888 Kpa 0 0.3495427 0.3039502 0.1823701 0.09118506 0.01519751 -0.0151975 -0.0303950 -0.0303950 -0.0455925 -0.0607900 -0.0607900 -0.0607900 -0.0607900 -0.0607900 -0.0607900 -0.0607900 -0.0607900 10 0.3647402 0.3191477 0.1975676 0.1063826 0.04559253 0.01519751 0 -0.0151975 -0.0303950 -0.0303950 -0.0303950 -0.0455925 -0.0455925 -0.0455925 -0.0455925 -0.0455925 -0.0455925 20 0.3951352 0.3495427 0.2279626 0.1367776 0.06079004 0.01519751 0.01519751 0.01519751 0 -0.0151975 -0.0151975 -0.0151975 -0.0151975 -0.0151975 -0.0151975 -0.0151975 -0.0151975 30 0.4103327 0.3647402 0.2431601 0.1519751 0.07598755 0.03039502 0 0 0.01519751 0 0 0 0 0 0 0 0 40 0.4255303 0.3799377 0.2583576 0.1671726 0.09118506 0.04559253 0.01519751 0.01519751 0 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 50 0.4407278 0.3951352 0.2735552 0.1823701 0.1063826 0.04559253 0.03039502 0.01519751 0.01519751 0 0 0 0 0 0 0 0 60 0.4407278 0.3951352 0.2735552 0.1823701 0.1215801 0.06079004 0.04559253 0.03039502 0.01519751 0.01519751 0 0 0 0 0 0 0 70 0.4559253 0.4103327 0.2887527 0.1975676 0.1215801 0.06079004 0.04559253 0.04559253 0.03039502 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 80 0.4559253 0.4103327 0.2887527 0.1975676 0.1215801 0.07598755 0.06079004 0.04559253 0.03039502 0.03039502 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 90 0.4559253 0.4103327 0.2887527 0.1975676 0.1215801 0.07598755 0.04559253 0.04559253 0.03039502 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 100 0.4407278 0.4103327 0.2735552 0.1823701 0.1215801 0.06079004 0.04559253 0.03039502 0.01519751 0.01519751 0.01519751 0.01519751 0.01519751 0 0 0 0 Fuel - Fuel Injector - Minimum Injector Pulse Width msecs 1.003036
-Eddie
1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60'
2021 Chevrolet Colorado 2.8 Baby Duramax
DAMN! THANKS!!! That looks very helpful!
J
