Ok, one thing to ignore is the 'packet formatting discussed'. Its for a specific cable not VPW. But the rest of the reading is good for you guys..
Vehicle Communication
“Modes” of operation to read data, read trouble codes and clear trouble codes. Mode 1,2,3 and 4. This communication is described below.
Mode 1
Mode 1 - Read OBD-II data, format ‘MODE-PP-BC’ PP=Parameter Identification (PID), BC=byte count to be received by protocol converter. Remember that the received byte count is actually double the value because each byte is transmitted as two ASCII characters.
PID 00 - return supported PID’s - send string ‘010009’ You would read 19 bytes, the V and the 18 ASCII characters which represent the 9 bytes response message.
PID 00 returns four data bytes, 32 bits, where each bit represents a PID starting with PID 01, a ‘1’ indicates a supported PID and a ‘0’ represents a non-supported PID.
Bytes 12-13 represent hex byte 1, 14-15 represent hex byte 2, 16-17 represent hex byte 3 and 18-19 represent hex byte 4.
PID 01 - returns MIL status, send ‘010109’
This PID returns two bytes of ODB test status
receive 19 ASCII bytes
Byte 1 -
MIL Status -------x
Byte 2 -
Misfire support -------x
Fuel support ------x-
Component support -----0--
Reserved ----x---
Misfire status ---x----
Fuel status --x-----
Component status -x------
Reserved status 0-------
PID 02 - Get trouble codes – used by Mode2 only
PID 03 - Get Fuel System status, send ‘010307’
receive 15 bytes from this command
returns two bytes, each bit is defined as follows:
Byte 1 -- Fuel System 1
open loop 1-------
closed loop -1------
open loop driving --1-----
open loop fault ---1----
closed loop fault ----1---
Byte 2 -- Fuel System 2
open loop 1-------
Fuel System 1 will be received as bytes 12-13 and Fuel system 2 as bytes 14-15 of the received data stream.
PID 04 - Get Calculated Load - send string ‘010406’
Receive 13 bytes
Returns one byte response in location 12-13 of received data
Calculated load% = b/255*100
PID 05 - Get Coolant Temp.- send string ‘010506’
Receive 13 bytes
coolant temp.C = b-40
coolant temp.F= (b-40)*1.8+32
PID 06 - Short term fuel trim bank 1 -send string ‘010606’
Receive 13 bytes
short fuel trim bank1 = b/128*100-100 %
PID 07 - Long term fuel trim bank 1 -send string ‘010706’
Receive 13 bytes
long fuel trim bank1 = b/128*100-100 %
PID 08 - Short term fuel trim bank 2 send string ‘010806’
Receive 13 bytes
short fuel trim bank2 = b/128*100-100 %
PID 09 - Long term fuel trim bank 2 -send string ‘010906’
Receive 13 bytes
long fuel trim bank2 = b/128*100-100 %
PID 0A - Get Fuel Pressure -send string ‘010A06’
Receive 13 bytes
fuel pressure.Kpa = b
fuel pres. psi = b*3*0.14504
PID 0B - Get Manifold Air Pressure -send string ‘010B06’
Receive 13 bytes
Manifold Pressure KPa = b
Manifold Pressure PSI = b*.29613
PID 0C - Get RPM - send string ‘010C07’
Receive 15 bytes
Returns two byte response in location 12-13 and 14-15 of received data
RPM=((b1*256)+b2)/4D
PID OD - Get Speed- send string ‘01040 Ù6’
Receive 13 bytes
Speed Kph = b1
Speed MPH = b1/.621
PID 0E - Get Ignition Advance -send string ‘010E06’
Receive 13 bytes
Ignition Advance Deg. = (b1/2)-64
