2004 Tahoe
5.3, 4L60E, AWD
LLP long tubes
OR y pipe
Borla cat back exhaust
MSD wires
Transgo HD shift kit
Airaid JR. intake
E fans off of a 2006
2004 Tahoe
5.3, 4L60E, AWD
LLP long tubes
OR y pipe
MSD wires
Airaid JR. intake
2004 Tahoe
long tubes, or ypipe, Borla exhaust, Airaid Jr. intake, MSD wires, AWD, 3.73
03 gmc sierra extended cab work truck sleeper lol 6.2 vvt with mast h.o cam headers, true duel 3in stainless 2 in 2 out magna flow dumped over axle 6l80,,, learning lots here
2011 Silverado Z71 5.3. Stock engine. Volant coldair, axle back Flowmaster 40's
2003 yukon 4x4 tuning for economy
I have 99 GMC 3/4 ton 4x4 Suburban with built 7.4L on dyno 430HP & 530 torque this is with 750 Holley & 2" dyno headers Most of the guys here say it will go up a good with the Vortec intake & Hooker truck force headers & 30 to 32 lbs injector The 530 torque is in by 3800RPM & the HP is at 4750rpm should work very well in 4.10 geared Suburban My Engine builder of 47 years experience say in should be in the 450 HP & more then likely 550 to 560 for torque My BIG ? is this MPVI tuner software work on my stock 99 Suburban computor would like to hear from guys in similar situation as what they did to tune their trucks
Hi
Jim here , 1996 s10 wynjammer 10-12 ps1 have software but havent tried tuning yet as it looks like i need to switch to a 411 pcm instead of the black box , i was told the black box was unsupported by hp tuners . does anyone have a base os for this setup ?
Jim
Me and a friend started tunning and well our area is mostly trucks.. Started testing out with a 08 silverado extended cab short bed with 323 gears and a 4.8 catless only .. yes i know its slow... went and ran it with stock tune catless hit a 17.6 .. then we put the tuned file back.. went 16.9 ... im satisfied for being first tune... yesterday we started with a friends truck 98 obs extended cab with a 09 5.3 swap.. 220/224 cam built trans 4l60e and 456 gears... was tuned before but really safe because tranny was slipping before.. now feels way better without Tq management 0 out and higher shift points.. ect..
wanting to tune my 08 tahoe for fuel mileage... 30k original mileage and only sees very nice days or family trips. Sometimes pulls my 26' enclosed with my car in it.....
just wanting to deal with torque management and also up the fuel mileage when loaded.....
where should I start?? In the repository of tunes and just glance over something or start from scratch??
Please someone correct me if im wrong , delete t/q in engine and trans and try bumping the timing up a degree or two and see what that does
Regards
JIm
I wouldnt say you are wrong, but I wouldnt do all that.
A bigger help is just reducing the amount of tq mngt in both the engine and trans. Getting rid of it all might just cause more problems. You can make it feel way better and drive better by just messing with some simple trans settings like slightly quicker shifts and adjusting the shift speeds to your liking.
Seems that in the 11+ trucks, you could add 4ish degrees of timing in various places without an issue and to keep it safe for just general driving and I've added 2-3 degrees to the DoD table without any issues aswell, but not all vehicles react the same. I still think you won't see much gain in mpg while loaded.
thanks for your input 5fdp
Regards
Jim
Personal opinion, I don't think I would rush to turn off torque management, especially if I was towing with a 4L6xE. you won't gain mpg and you will lose trans life. 4L6xE's aren't the best for long life, not the worst, but not the best. I would take good care of it.
Just saying.....
Datalog under load with the big trailer. Make sure you aren't hitting PE while towing, Tune to ensure no KR while towing. (shoot for worst case conditions and make a safe tune for it) Watch the high load/low rpm range, pretty sensitive there.
Hello to the group i have a 2010 1500 4.8, rear home brew turbo, billet servo's, 44lbs injectors, full length headers, still a work in progress. got my hp pro two weeks ago.What a learning curve. waiting for the Holley mid rise intake to show up next week and new 60 lbs injectors. then we can start all over.
hi all, got my hp tuners a few weeks ago and have wasted no time diving in and learning and tuning, i got the tuning schools beginners books and than read the all forums till my eyes fall out hahaha, anyways i got a 2004 silverado 2500 CC has Lts,ls2 coils, NNBS intake swap, 05+ efans, CAI, soon to come ported 317s and a cam swap.
2000 sierra, built 6.0 200 shot
2002 Silverado 2500HD LQ4/4L80E up here in Labrador, Canada.
I just recently picked up the software, so I'm learning and making minor tweaks, but this software truly opened up a whole new level of learning for me.
I have a 2008 Z71 Lifted,35's, Billet Servos 2nd,3rd,4th w/ Monster Billet Cover,cold air,shorties,custom ypipe,3inch into a Spintech,HP Tuned w/ no Torque Management. Having fun, but still learning everyday!
new here what's up !! on its way as I speak !! need help .
05 LS1 Custom Grind 227/230 - 110 . 612'' lift comp cam, Pac racing double springs, comp cams Hi-tech chromyl pushrods,130#seat,337#opean,titanium retainers, cylinder heads are 2011-799 casting low miles A.R.P. studs , milled .035'',3 angle valve job ,deburred ,and polished, comp cams gold roller rockers , specter cold air intake ,custom tune by {Tuned by Frost }w/t HP TUNNER! TCI,2200 stall converter 4l60e,rebuilt tranny VETT SERVOP. Pace Setter long-tube w/t Flow Master 44 series.
Count me in. Bought Hpt for xmas for myself, been reading and tuning ever since.
2006 VMAX.....Long tubes, cold air, cat delete
1985 GMC crew cab....... 2005 lq4 swap, th400 (just finished custom 4l80e w/ custom 2.97 1st gear setup to replace th400)
