Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: 6L80E, holding tranny in drive on the dyno
    Advanced Tuner WS6HUMMER's Avatar
    Feb 2006
    Pineville La. US
    771
    Quote Originally Posted by HeavyChevy305 View Post
    If you went with these changes then yes you can.
    Yes that's what I did. I noticed the only way to make it hold 3rd was to do that, drop it in 3 manually then command that gear with the scanner. Wouldn't work just dropping it in drive and commanding 3rd with the scanner function. Thanks for answering my question.
    99 T/A WS6, original LS1 turbo
    Sep 2015
    5
    Am I setting Trans Overtemperature or Cmd Gear Control Limits?
    Oct 2017
    19
    You must modify your calibration to allow you to lock it into gear using vcm controls as most calibrations do not allow it over a specific RPM and MPH
    Attachment 43505
    so to do this all i do is modify the values for the RPM and VSS? what do i enter in the up and down shift mins????
    Dec 2019
    11
    Does this require the trans computer to be unlocked as well or can this be done via the ECU for the engine?
