I'm working on an 05 NA GP That has a FWI, ported front manifold, and a 2.5" catless DP. The trims are showing that the car's too rich, and I can smell the richness, as well. The problem is that the o2's are showing in the lower range, indicating lean. The car has 35k on it, so I'm hoping the sensor is still good. When I pull fuel to lean it out per indication of the trims, I start getting KR in the middle area of the table. Here's the last scan we took with the fuel trims still in the negatives.
