g/cyl maxing out on a 2002 GTP
Customer of mine changed pulleys on his supercharged GTP and added a new MAP sensor and LS1 MAF. Now, when we try and tune the car we run into a weird situation. At about 4000rpm, right when we reach 140g/cyl, the car stops. I hit fuel cut.
He is running a larger MAP and MAF so one would think that the car would think we were running less g/cyl than we actually are. What am I missing, how can I get more boost than the factory hard coded limit?
Do you mean the tables themselves?
when datalogging, the histogram shows me maxing out the table. So my assumption is that I am maxing the table parameters. I wound find it odd that the car hits fuel cut the moment it taps out the 140 g/cyl that the histogram shows if infact its not limited in the computer
Do you have a scan you can post?
I will see what I can do about getting a scan log
