Anyone know much about these as far as tuning? Need to know what base fuel pressure should be.
Base pressure is 55-60 psi , and tunning is mostly done by Splitsec or AEM.
The base fuel pressure depends on a lot of things, a stock Viper truck is about 55 psi as mentioned above. What is on the truck to tune it, ie piggy-back, extra injectors, VEC2/3, split-sec,etc. What size fuel injectors, how much boost, etc.
If you wind up tring to tune this with some sort of piggy-back, reprogramming the stock controller to eliminate the enrichment delays will save you a lot of hair pulling and possibly your, or the customers motor.
- Chris
Thanks for all the updates in this thread - it may be a few months old now, but it's been interesting to flick through none the less.
comparatif simulation taux credit auto - Taux crédit auto. Comparatif des offres! Les meilleurs taux crédit auto sont sur le net !comparatif simulation taux credit auto
