Originally Posted by
madden
Here's what I want to do: I'd like to run through the traps in 4th gear at around 3900 rpms on the drag strip. My theory is that this will reduce damage to the C3 clutches by keeping it out of 5th gear. I know that the best power is to be had at around 3200 -3400 rpms but this theory is centered around having fun at the drag strip without limping.
On my LB7 there is a tab under engine>fuel control>fuel shutoff> RPM Limits. This tab does not appear on the LBZ. One thought that I have was to tune the tranny to shift at the desired rpm at the 4>5 WOT upshift. I guess I could do that in the tow/haul mode only and then you could use the tow/haul button when you want to quarter mile race. Is this how I should tune the LBZ to run up to 4100ish rpms in 4th gear or am I looking in the wrong direction?
