Results 1 to 3 of 3
Thread: LBZ DTC P0108 after tuning ....... any thoughts?
    Sep 2008
    49
    I've just tuned an LBZ truck and its running really great but it's throwing a
    P0108 Map sensor high voltage code. I've read a thread somewhere about a predator handheld tuner doing this same thing before. Does anyone have any ideas? I don't really want to disable the ses for this code if I can "fix it" properly.
    Thanks in advance!
    Jul 2008
    21
    My LMM was throwing this code after a began throwing more to my tune and unfortunately I had to disable it. Basically the map sensor can't handle the quick increase in pressure and throws the code consistently under hard acceleration. I researched this code thoroughly before deciding that disabling it was the only way around it. I did this about a month ago and have no other issues. Good luck!
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    Did you raise the high fail voltage or the timer instead of just 'shutting off' the code ?
