Ok, I've read, read and read some more. I've searched, but no luck.
When I do a cold start, it searches bad for 45-60 seconds then settles in. The problem is, that it searches so bad, that it stalls most of the time if it's too cold.
I don't think it's a RAF fueling issue, because at the beggining of the cell, it's adding some fuel, but by then end of the cell it's pulling. Also, it's still in the same cell when it stops fluxuating. The funny thing, is if you look at my idle airflow table, it's at 25 at 20c, and it's pulling 3-4, but just a week prior, it was at 21 and adding 4.
Look at the log from 10-15, in the 20c cell, it was calling for a desired airflow of 26, but on the 11-02-08 cold startup, it had a desired airflow of ~21.
Who knows what's going on. I did notice that in my meddling, I turned on the fuel trims in hopes that it would help, but obviously it didn't.
So any help would be greatly appreciated. This is the only issue with the tune now that I am struggling with. It's weird that it only pulses/fluxuates for 45-60 seconds and then settles in.
Thanks.
Here's tune and data.
