Results 21 to 40 of 48
Thread: '06 SS/SC 2.0 VE tuning
  1. #21
    Quote Originally Posted by dont_blink View Post
    What size pulley? Just the regular GM stage 2 one?
    The pulley is a ZZP 2.8
  2. #22
    This things setting a Crank sensor code, how will that effect the running of the car?
  3. #23
    Advanced Tuner dont_blink's Avatar
    Feb 2008
    Denver, CO
    466
    A LOT. It's going to affect timing in every table as well as fuel injector timing. What did you do to the crank? You didn't swap PCMs or anything did you?
    RSG Offroad
    Jeeps. Jeeps. And more Jeeps. Oh and Jeeps too.
  4. #24
    It's got new Diamond pistons on the stock rods and crank. I ordered a new crank sensor today. I did the Case Learn with HP and the light went out for just a few mins. and the car seemed to run better.
  5. #25
    Feb 2008
    Denver, CO
    466
    Soo...when you put the crank and rods back in did you check the clearances? Or did you just slap it all back together, tighten the stuff down, and call it a day?
    RSG Offroad
  6. #26
    I didn't do the work on the engine it was done at another shop.
  7. #27
    Feb 2008
    Denver, CO
    466
    Okay. Did they install new bearings or use factory ones? If the correlation between your cam sensor and crank sensor is off then that is going to cause issues. Did they use adjustable cams gears? Were the cams you put in regrinds, blank grinds?
    If they installed modified cams and didn't use adjustable gears, I would be willing to bet that is at the core of all your issues here.
    RSG Offroad
  8. #28
    The bearings are the stock bearings reused, the cam gears are adjustible, and the cams are blanks that cam from Bates Engineering. I'm not sure if they degreed them or not and the one's that did it went out of buisness.
    I ordered a new crank sensor from GM to see if that solves this.
  9. #29
    Feb 2008
    Denver, CO
    466
    A new crank sensor is not your fix. If they ground the cams themselves and left the cam gears at 0 or something, this is surely part of your problem.
    RSG Offroad
  10. #30
    Were can I find info on this, I've never worked on one of these I4's. Are Bates cam's not good cam's or is it you just have to degree them different? Hell I don't even know if the other shop degreed them or not.
  11. #31
    Would you mind giving me call?
  12. #32
    Feb 2008
    Denver, CO
    466
    Every cam regrind should be degreed properly, which usually calls for the use of an adjustable cam gear on each cam. If the cam and crank sensors are not reading in sync you will get all kinds of codes and rough running issues. Pull off your valve cover and check, it's pretty easy. I believe they even have a run through of how to degree cams in the Ecotec in the Ecotec build book. It's worth buying to read or finding it posted up online somewhere.
    RSG Offroad
  13. #33
    Feb 2007
    13
    All of the build books are posted on www.GMTunerSource.com
    HPTuners, Diamond Forged 10.0:1 Pistons, Flowtechnics Ported Head, Ferrea Valve Springs with Ti Retainers][/B], ARP Head Studs, Siemens 60lbers, AEM Cold Air, Magnaflow Cat Back, GMPP Header, BilletFlow 2.9" Pulley, Cobra Heat Exchanger, ZZP Downpipe
    Special Thanks to all the guys down at Vera
    Vids of the Beast
    Pics of the Beast
    Member #001 - Sticker Tower Of Doom Club
    ACHA DII FAU Goaltender
  14. #34
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    466
    Set your dynamic airflow to 1500/1400 respectively and call it a day. This doesn't disable the MAF, it makes the car ignore the VE table above 1500rpm. Just listen to the guys who have tuned 100s of LSJs please.
    *shutter*
    You must like leaning out on shifts then....
    Doing it right means spending the time to dial in both the VE and the MAF.
    Tyler
  15. #35
    I have the book, anyone degreed the cams in the car? Is there a right up on it anywhere?
  16. #36
    Aug 2005
    Maidstone, SK
    466
    The LSJ build books says exactly how to degree the cams.
    Tyler
  17. #37
    Quote Originally Posted by omega_5 View Post
    Yeah, they do it on a engine stand. I wasn't sure if there was room, but now that I have it apart it looks like there will be just enough. I did find that the shop that did the install didn't have the colored links lined up on eighter chain.
  18. #38
    May 2006
    Waterbury CT.
    293
    Quote Originally Posted by LS1408 View Post
    They only line up maybe every 8 revolutions of the engine.
    They start out lined up till you turn the motor over once.
    Ted.
  19. #39
    Feb 2008
    Denver, CO
    466
    *shutter*
    Bite me.
    RSG Offroad
  20. #40
    Dec 2008
    Nevada
    4,452
    you have 42#'s and a 2.8....u should really be on the 60's
