Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: hows it look
  1. #41
    hmmm thats wierd.. cause i only added 6,7,8,9 histo.
  2. #42
    heres a scan at idle.
  3. #43
    ok i got some other scans it it kinda is extreamly fustrating with the wot run and even some cruising...... ill post them up but like for the wot runs when i get her ready and just at take off my car LUGS REALLY REALLY BAD than whe picks up and sometimes for my cruising its like when i hit a certain part of the throttle she really lugs hard again... its really frustrating.
  4. #44
    o and heres the stock file.
  5. #45
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    I set up your tune for you. Also set the trans tables to firm up the shifts & the shift points.
    When doing the WOT scanning, command 2nd gear with the VCM controls.
    Russ Kemp
  6. #46
    wont open, says it is outside the bounds of array, what ever that means
  7. #47
    Dec 2007
    248
    It means its so bad ass that it won't load
    98 - z/28 Twin TC76's l forged 347 l boost cam l moser 9" l th400
    07.5 - GMC Sierra 2500HD D-Max daily
    09 - G8 GT wifes daily
  8. #48
  9. #49
    Dec 2005
    Regina, Sask.
    4,214
    You may need the latest BETA to open my .hpt file.
    Russ Kemp
  10. #50
    i got the vcm 2.22 and downloaded the .net but still wont work still says the same thing
  11. #51
    and what beta
  12. #52
    and where would you get it
  13. #53
    is it the beta version of the net.frames?
  14. #54
    Advanced Tuner jackedupcanyon's Avatar
    Sep 2008
    North Atlanta, GA
    295
    Think you need to get Bill@HPT or support to either get you the beta or convert that file back to an older version (not sure if they can do that?). Might link this thread. Other than that, ???
    Steve
    2007 GMC Canyon Z71-4x4 | 3.7 I5-Auto | 4" Skyjacker suspension lift | 3" Performance Accessories body lift | 33x11.5x17 tires (going 35x12.5x17) | 3.73 gears | 57 K&N | BPi VS | AMS EaAU 6081 | SSK MAF Adapter | NGK AFX w/ NTK WBO2 | AMSoil fluids
  15. #55
    Sep 2008
    North Atlanta, GA
    295
    Russ Kemp aka Bill?
    Steve
  16. #56
    hey Russ Kemp, loving the tune but there are some question i have on some of the table that you changed... the first thing is the tps senser calculated airflow under eng/diag..... what did you do there and how did it affect my car...than under transmission for the auto tcc/tcc duty cycle/ min-max and the apply and realease speed for them what does that exactly dew and how does it affect my car, also would it be to much for my clutch bands? but i love how my car is and how firm the shifts are... if you can answer these questions it would be awsome thanks.
