Results 1 to 7 of 7
Thread: Anyone try to make a real power pid?
    Nov 2006
    2,801
    Instead of using calculated torque and playing some math on it has anyone tried to find power and torque using the fundamental dv/dt?
    I tried it in excel but all I'm getting a ton of noise from the slow frame rate, gear changes, and wheel spin.
    Tuner at PCMofnc.com
    Nov 2002
    Central Florida
    2,503
    I think you'd be better off with an accelerometer
    logged through the EIO. That, and a coast-down
    curve that will show you your road and wind losses
    which you can back-figure to a HP/MPH correction
    curve. You can get eval boards for about $30 or
    an old red-LED G-Tech will let you pigtail out an
    acceleration voltage signal.
    As a tune-to quantitative feedback, acceleration vs
    MPH is about as good a "road dyno" as you could
    want (wind speed variability aside).
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    I have one in the works.....just a few issues still....but I have the math part of it worked out and I know what is needed for it to work...
    -Scott -
    Oct 2004
    Orlando FL
    766
    Quote Originally Posted by jimmyblue View Post
    You can get eval boards for about $30 or an old red-LED G-Tech will let you pigtail out an acceleration voltage signal.
    I have a Gtech which has the red display in front and has the 3-position sliding switch on the front. Is this the model you're referring to? If so, the case doesn't appear to have native provisions for a pigtail?
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
    Sep 2008
    1,668
    I'm curious about that as well...I've also got an old school G-Tech (had it for years now)...I don't see any way to pigtail out of it...but I also haven't tried to open it's case yet.
    Apr 2005
    4,387
    I've got a working excel sheet now...
    now I just need to streamline a few things ... add an SAE correction option....
    see if I can turn it into a program maybe using .net stuff
    I need to get more data from some real dyno runs and some more .hpt files from thise dyno runs as well...
    but its coming along and maybe sometime soon I'll be able to post it up
    I'm getting into a point where my real job is very busy right now so I dont have time to work on this....but kow that I am working on it when I can...
    it could be march before I'm even ready to post the excel sheet that I've been developing.......
    -Scott -
    Advanced Tuner arthansen's Avatar
    Apr 2004
    Tampa, FL
    425
    About 5 years ago I developed this spreadsheet. The first tab has instructions. I left in data from one of my "runs" to show what it looks like. This was my V6 Firebird and it dynoed at 322 RWHP(Cam, Headers, 100 Shot Nitrous). The run I am showing showed 309 RWHP.
    http://web.tampabay.rr.com/jakerace/HPCalc.xls
    Check it out.
    2013 Jeep Wrangler JK
    3.6 V6
    More MODs than Stock
    2018 Ram rebel
    5.7 Hemi V8
    Stock
