Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: 2bar 4.3l?
    Jul 2005
    arkansas
    530
    2bar 4.3l?
    can i get 2 oe 3 bar map on a 2000 silverado with 4.3l? i really really need it. i'm working on a set up that will be running 15+ pounds of boost at track but 10 on the streets. i don't want to have to retune between the two. it will be runing marine intake, mpt-70 turbo, with a modded set of syclone manifolds. heads have been ported and polished along with a 5 angle valve job, comp cam, SBC blower pistons and eagle 4.3l H beam rods. i think that about completes the list. should be a fun build.
    2 or 3 bar will make it even better though.
    '04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, Circle D triple disc 3,000, FLT LVL 7 4L60E, L92, 227/235 111lsa.
    Old 5.3=12.33 @110mph
    http://www.streetfire.net/video/turb...mph_741849.htm
    Jul 2005
    arkansas
    530
    can i do a full rewrite and load a newer model os onto his computer so i can get 2bar?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,282
    Check the OS tab for the available custom operating systems for your application.
    Jul 2005
    arkansas
    530
    its completely blank
    HP Tuners Support
    (foff667)
    28,282
    Yeah, its not a pcm that supports custom operating systems.
    Jul 2005
    arkansas
    530
    that sucks so what can i do? does that mean doing a full rewrite of another os wouldn't work?
    HP Tuners Support
    (foff667)
    28,282
    There are no custom operating systems available for the older vortec pcm's, flashing in a different OS won't help you in this case since none of them have custom operating systems.
    Jul 2005
    arkansas
    530
    so can i swap the pcm? i downloaded a few tunes off the hpt tune site and they had 2bar ability. one was a van i think another was an s-10. would one of these plug in?
    HP Tuners Support
    (foff667)
    28,282
    I doubt they would be a simple plug & play pcm into yours.
    Jul 2005
    arkansas
    530
    hhmmm, so how can i find out some options. he is looking for 500-550 hp here so i don't think maf is gonna cut it.
    Dec 2006
    16
    You'll have to swap in a 2001+ computer to get the tuning availability. I think that's your best bet using HPTuners. I use the 2bar OS on my 01 4.3L
    Tuner UR50SLO's Avatar
    Nov 2007
    N. Indiana
    110
    Exclamation
    I know I'm talking with you on the Sy/Ty board as well.
    We still run the 98 ECM in ours. I just set the power enrichment to where I get 11.4AFR at WOT and I'm done. Everything else is 14.7-1 when driving.
    It'd sure be nice to have the 2-3bar ability but I've had no issues getting it to have the AFR I want on the wideband with the stock system.
    I can send you over my files and you can start with just my Power enrich and see what happens at low boost first. Should be shooting for 11.7-11.0AFR.
    If you don't have a wideband.. get one before putting any boost to it.
    We are at 10-11psi now with no knock. I had it turned up once so I know it'll go above 15psi with no problems. Just don't need that much power at this point as it's a driver not a racer in our house. That's what we have the Camaro and Typhoon for.
    Send me a e-mail I can really help
    Scott
    [email protected]
    Jul 2005
    arkansas
    530
    files would be good. email is [email protected]. the turbo won't be going on right at the moment but after the first of the year. i have to get the stupid thing runing better first. we will be runing meth also. we deffinatly have a wideband. i told him i wouldn't touch the truck unless he bought one. so he got the ngk like i told him.
    SHIFT220 was it a plug and play or was there more envolved?
    thanks guys!!
    Jul 2005
    arkansas
    530
    here is a log. the map doesn't move with throttle and maf its a little bit delayed and i wonder if it has a leak or something causeing the problem. where the timing is really high i was demanding ti to see if maybe the distributer was retarded. didn't seem so.
    Dec 2006
    16
    Quote Originally Posted by 4.8t View Post
    thanks guys!!
    Sorry for the late reply, I don't check back here often. I'm 99% sure it is not a plug and play but I haven't done it myself. My best guess would be that you'd just have to splice a bunch of wires into the new harness for the LS1-style computer.
    Jul 2005
    arkansas
    530
    thanks, I'll take a look at it.
    I've made the conversion from a 97 engine to be controlled by an 01 PCM. Really not hard to do. Easiest way to do it is to swap the whole harness, if possible. I don't know about a Silverado, but on the 97, there wasn't a separate engine and chassis harness, just one big one.
    I can send you the PCM pinouts for a 00 and an 01 PCM. To adapt your old harness, you'll need a pair of connectors (lemme know if you need the part #s, but I did see a set for sale over on s10planet.com), then use the pinouts from the 00 to determine what each wire is. With that info, find the location on the new PCM and rebuild your harness accordingly. I know the 00 and the 01s use a few different sensors, namely the knock sensor, so you may have to rebuild that circuit with a new connector and new sensor.
    PM if you need the pinouts. I can email them.
    Jul 2005
    arkansas
    530
    let me find out if he wants to do it or not. if he does i would appreciate the help.
    Jul 2005
    arkansas
    530
    UR50SLO here is the latest log.
    Jul 2005
    arkansas
    530
    eat-pez, i would love to have those pinouts.
