I got a copy of this gm tune and it looks funky at best.
There's more changes to the maf tables than there is to the desired air load table, it seems almost useless to any of us.
Aaron
'03 Z06 Corvette - The Normal Stuff.....
EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
EFI University Evangelist
Well does this tune take a shit over 23psi or does it play ball?
Me love boost long time.
I did a compare of a stock 2008 HHR SS file and GM Stage 1 file and the first thing I noticed is that The HPT software is only looking at 69 of 114 parameters. Of the 69 it looks at there are only 15 differences with 54 similarities.
I'm guessing there are a lot more than 15 parameters that have changed.
I wonder if the 2 sensors and harness are available without buying the entire kit.
Sensors and harness are available separately but they won't do you any good without the reflash. The reason we see so few changes is because we don't currently have access to some of the other key tables and parameters.
There are some other fuel and boost control code that GM used to gain HP/TQ.
Up till now, we have all been modifying air load parameters to increase boost and GM barely touched these tables to get 20 lbs. Hmmmmm, are we missing tables?
I'm hoping we will see some additional tables/parameters soon but I'm not holding my breath.
It seems HPT did a good amount of work on the LNF and then moved on to other more equitable platforms.
Aaron
Can't I take the GM Stage file I got from someone that purchased the GM tune, add the new sensors to my car and flash with the tune file? Will the HPT software update everything even though it doesn't open those tables to us?
It's still unknown if they get into the BCM and modify anything.
Chris White
www.GTOShiftLight.com
2006 GTO Spice Red A4
2012 Jeep SRT8
2013 SRX Custom IPC/BCM/CUE
2013 XTS4 Custom IPC/BCM/CUE Auto High Beams
2013 Volt Custom IPC/BCM/Radio
GM claims to have disabled the learn down code in this Stage tune. Would be nice to try and see if we can do that to the standard tune as well.
the changes are in the ecm itself. not the bcm. what people are failing to see is. we. the hpt users, do not have access to the tables that gm changed.
the lsj suffered the same problem
I understand we don't have access but does that mean when you do a flash or read it is not reading/flashing the entire code base?
Or is the HPT software only reading parts of the ECM? The file compare function seems to indicate that it reads everything but we only can change parts.
Hopefully Chris can chime in and clear up some stuff here.
Has chris or Bill had a look at the new flash?
Perhaps it could help point where the issue is? Or help unfold new tables?
I dotn want 600 tables to look thru. I just want the ones that encompass the WOT type modes.
heres some logs of stage 2 on stock car
2007 solstice gxp:gmpp; turbo upgrade, cai, PAW; intercooler, pipes, z0k; rear sway bar, rear brace. magnaflow, 18x9 ultraleggeras, 275 kumho xs, brake pads, kw v3's w/6k springs, energy suspension bushings, hp tuners, solo high flow cat
TEAM FAIL RACING
heres some logs of a tuned stage 2 on stock car
TEAM FAIL RACING
