The logs posted appear to flatline at 255kpa
Me love boost long time.
But it is now a 3 bar sensor if I'm not mistaken. Doesn't that change the definition of the 255kpa apparent reading or am I off on that? Still learning this stuff.
I wonder if it's beign interpreted correctly since the op system has been changed
If the op system was changed that drastically i doubt you'd be able to read it and manipulate it, its almost like it wasn't changed to read those sensors properly. Maybe all gm did was change the desired air load and that's it?
The new sensors just report a lower boost reading to the ecm, i doubt it would freak out since the maf tells it exactly how much air its ingesting.
Anyway we'll find out soon enough.
The Maf tables are scaled lower than the stock tables.The long term fuel terms are also positive 10-14 percent as well after seeing some street datalogs.
It will be interesting to see what others have datalogged.
I bet the fuel trims are at 0, but our scanner won't read the new OS correctly. That wouldn't make sense that the PCM has to add that much fuel in to compensate for programming. Unless GM REALLY screwed something up lol.
RSG Offroad
Jeeps. Jeeps. And more Jeeps. Oh and Jeeps too.
Or those logs came from a car with an intake.
sent a couple logs and the file to support@hptuners
ps i have the gmpp upgrade, 2007 sol, 5sp
2007 solstice gxp:gmpp; turbo upgrade, cai, PAW; intercooler, pipes, z0k; rear sway bar, rear brace. magnaflow, 18x9 ultraleggeras, 275 kumho xs, brake pads, kw v3's w/6k springs, energy suspension bushings, hp tuners, solo high flow cat
TEAM FAIL RACING
Post some logs here too
.….and the tune file
Aaron
'03 Z06 Corvette - The Normal Stuff.....
EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
EFI University Evangelist
The one that was sent to us is actually already a supported definition so maybe we got one an just didn't know
i'll call the people that did the tune tommrow to see if the file that i have is with or without a tune. i dont have my computer on me so i cant see what it is. i'm on vacation visiting family. i got the gmpp turbo upgrade and a good tune done. christmas gift for the car.
TEAM FAIL RACING
hmm I"m interested in seeing what PCM changes gm did here.
2006 cobalt (no more turbo)
m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
2014 wrx mild tune 18psi pump gas
With the "learn down" code disabled and "no lift to shift" code added i'm sure Chris will be able to see those differences between the stock file and the gm tuned file. And hopefully these feature will get into our hands soon enough
I wonder how much the BCM plays a role in the no lift shift.
i uploaded it to the repository. awaiting approval.
it was a stock gmpp lnf turbo upgrade file. no tuning.
TEAM FAIL RACING
