I need some log files from when you were/are on the dyno...
I'm working on a project and I need some log files from your dyno
things that I need in the file:
Vehicle Speed (SAE) mph
Engine RPM (SAE) rpm
Throttle Position (SAE) %
Trans Calculated Gear Ratio
Vehicle Weight
Vehicle Type
AFR if you can provide it
I prefer that you log less than 12PID's worth on the dyno if you are making a new file so I can have a higher sampling rate
If you can provide me with the Dyno Reults and a screen shot or a copy of the actual printout that would be even better
at a minimum I need to know what the result HP/TQ was from your dyno
yes..I'm working on a worksheet...
no dont ask me when its going to be done....
I will share as I get it close....or if I need some help figuring something out...
just attach it all here
