Results 1 to 10 of 10
Thread: Injector question
    Injector question
    Can anyone tell me the ?lbs/hr of these injectors. (Delphi 25320288) They came in a 2000 6.0 silverado. I need the info so I can update the injector field in HPT. I looked on the web and can find the injector but not the lbs per hr.
    Here are all the numbers on the injector.
    25320288
    17113553
    8149B
    3A
    Thanks in advance.
    2002 Chevy ECSB, 6.0 - 4L80, Comp Cam 226/270 .520/.524 Lift 115 Lobe - Magnaflow exhaust -Free flow cats K/N Kit - Electric fans - 3.73
    Dec 2007
    248
    I'd post on performance trucks and see what you can find.
    I searched there and found conflicting results. 25.7, 28, apparently those are ran in the 4.8l also.
    98 - z/28 Twin TC76's l forged 347 l boost cam l moser 9" l th400
    07.5 - GMC Sierra 2500HD D-Max daily
    09 - G8 GT wifes daily
    Thanks 98Camarod. I found on line the cc/min is 226 which coverts to 21.53 lbs. The dealer thinks there 22lbs but there not sure. I'm going to roll with the 22lbs for now and see what happens, but I will post on performance truck. Thanks for the help.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    You could have just looked in a stock tune, it is the easiest way with all the false injector numbers all over the internet.
    Sulski Performance Tuning
    Feb 2008
    665
    I am about 95% sure that they are 24.7 lbs an hour
    2017 Silverado LTZ
    Feb 2007
    San Antonio, TX
    1,255
    Quote Originally Posted by WS6FirebirdTA00 View Post
    , Ditto.
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Feb 2006
    central michigan
    349
    that 21.53 lbs rating is at 43 psi . these are rated anywhere from 24.8 to 25.7 in stock gm tunes.
    Would that be flow rate vs kpa. Because that shows 24.25
    Jan 2005
    Concord, NC
    8,093
    yes, look at 0 kPa vac. and that is the flow rate at the stock pressure
    Thank you.
