Ok, i've been trying a few different methods and am getting slightly different results every time. now i'm not sure whats the best method for my G8. I have tried to read other threads and guides but am still not sure. especially since i dont have a true VE table, so i'm not tuning the VE table.
Should i first use my wide band to to dial in my commanded PE AFR via MAF AFR error? Like 7000Hz+ (with disabled LTFTs in open loop)
then re enable LTFTs and closed loop to dial in my part throttle LTFTs via LTFT % error? (reason i want to dial in the LTFTs with my NBs vs using the WB to 14.7 is that the two are not agreeing on whats 14.7 AFR. i trust the NBs to be more accurate at 14.7) When i use the WB to dial in part throttle AFRs to 14.7 in open loop, I am still getting positive LTFTs after re enabling closed loop.......
maybe i'm just not doing something right
some one please give me some better insight
