Results 1 to 1 of 1
Thread: Can someone take a looksee at this scan
    Aug 2008
    Shawnee,kS
    81
    I lost a 2/4 band and a set of 3/4 clutches within a couple hundred miles. Come to find out the person who put my trans in didnt adjust my shifter cable. When the shifter was in OD the tooth on the gear was not sitting fully in the gate. It was on top of the tooth between OD and neutral which some has told me will bleed line pressure off. Is this true? Anyways! I did a ~30 minute log tonight just to make sure I wasnt missing anything that could be harming the rebuilt trans. I have a question regarding force motor line pressure. If you look when I am cruising along at about 70mph the line pressure % is at 0 alot. Is this normal for just hardly on the throttle keeping up? At the end of the scan I also leaned on the car for a few seconds right quick. Anything troublesome looking there? Also I am kinda questionable about my trans temps. It was about 20 degrees outside and I have a decently sized cooler. Is 106F over cooling the trans?
