Ive seem to have found a sort of bug in HPT. I noticed it when this last version came out (I believe it was this one) but the behavior I was experiencing, I attributed to my last transmission failing. Now after replacing the trans with a TOTALLY different unit, the same thing is happening.
Without regard to any transmission tables, even writing the stock tune back to the truck:
On the 2>3 upshift, the direct clutches (3rd gear) will engage, then disengage for a half second, then re-engage and hold until the next event. It happens in the towhaul/perf mode & cruise control modes as well.
Using the scanner, I can put the shifter in first, and manually command all upshift events and when I click from 2nd to 3rd in the scanner, it shifts flawlessly. All other times, I have problems.
I can provide a vcminfo thing and anything else ya'll need. I would really appreciate any info at all, as I'm worried about the longevity of my direct clutches
