Results 1 to 7 of 7
Thread: 2-bar Timing Adjustments
    Oct 2008
    29
    The high octane timing table only goes up to 1.2 g/cyl. I hit this with 1lb of boost. Is there basically no way to ramp timing up and down based on boost? The numbers you put at 1.20 g/cyl stay steady as you go into max boost? I am seeing more than 2.0g/cyl
    Advanced Tuner TXZ0603's Avatar
    Dec 2007
    Houston, Tx
    375
    subscribing
    2003 Z06
    Forged 347
    PTE Billet 67/65 Turbos
    FMIC / Dual 50mm Tial BOV's
    ID 1000 Injectors
    RSI Stage 4 Fuel System
    07 Z06 Cam
    Tripple Nozzle Meth
    ACT Twin disk clutch
    25# Boost
    Oct 2008
    29
    Come on. Sombody has to be able to verify this.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    That's it; you max out. There are some tricks such as halving IFR and VE and other airflow tables, but I still expect that you'd max out the table.
    Steve Williams
    TunedbyFrost.com
    Dec 2007
    Houston, Tx
    375
    Frost, could you eloborate some on which you speak?
    2003 Z06
    Forged 347
    ID 1000 Injectors
    07 Z06 Cam
    Tripple Nozzle Meth
    25# Boost
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    If you half the IFR you will have to cut back your VE by half as well (faking small injectors makes you rich, meaning the VE will need to be lower).
    This is a hacked way, but if it is really needed is about the only way around it. This means if you see 600 g/sec then you should now see about 300 g/sec.
    Sulski Performance Tuning
    Jan 2006
    Richmond VA
    1,950
    You can scale back quite a ways, you just really need to keep up with what you are doing. It will crunch down the whole timing table (and many others!)
    Steve Williams
    TunedbyFrost.com
