Attn: RussK
Would you please look at my trans log using your config. setup? I'm having a upshift problem from 2-3 and it seems like all shifts are taking too long to actually complete. Its a 3200 converter and built transmission with a corvette servo and shift kit. Thanks in advance!
Need more info, tire size, desired WOT shift rpm, brand & stage of shift kit and engine mods. Also need your stock tune to compare.
Russ Kemp
During that pass I was running 26" mickey thompson et drags, but it also hits the limiter with my 315/35 17 goodyear gsd3's. My desired shift RPM is 6400 and the shift kit is a trans go and its on the lowest setting (i believe, tranny builder installed it).
Engine mods:
2001 Trans Am stock bottom end
233/239 .605/.610 112+2
stock 241 heads
pacesetter longtube headers
Texas Speed true duals
ls6 intake
p&p throttle body
175 nitrous
moser 12 bolt
3.73 gears
built tranny with corvette servo
shift kit
I think I covered everything. Sorry it took so long but I was out of pocket this week. Thanks again!
Stock tune is below. And the scan was done with your trans config.
Try this trans tune. I set the speedo for the 315/35/17 tires.
Russ Kemp
Your the man! I really appreciate that! I'll have to try this out tomorrow as its pouring down rain here right now.
