Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: 64 bit vista guys that have gotten the drivers to work come in!
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,262
    Exclamation 64 bit vista guys that have gotten the drivers to work come in!
    I'm trying to create a sticky for those who have a 64 bit version of vista that are having problems installing the drivers.
    Please let me know step by step of what worked for you.
    Some of linked to this exe file http://www.ftdichip.com/Drivers/CDM/CDM%202.04.06.exe and it seems to work for most but I would like a step by step of what you needed to do to get it to work correctly so transitiion is as easy as possible ie
    1. run exe file found here http://www.ftdichip.com/Drivers/CDM/CDM%202.04.06.exe
    2. download drivers found here http://www.hptuners.com/pub/HPT_MPVI_Drivers.zip
    3. extract drivers to desktop
    4. connect interface to pc
    5. install drivers
    6. done. at this point everything should work flawlessly
    from the sounds of it thats what should happen but seeing I don't have vista 64 I really need to confirm.
    Secondly the F8 disable is it just this simple?
    1. Turn on pc & hit F8 several times until the advanced boot options menu appears as shown here http://www.hptuners.com/forum/attach...4&d=1190216052
    2. select disable driver signature enforcement
    3. continue to start pc
    4. download drivers found here http://www.hptuners.com/pub/HPT_MPVI_Drivers.zip
    5. extract drivers to desktop
    6. connect interface to pc
    7. install drivers
    8. done. at this point everything should work flawlessly
    Thanks guys for all your help...this will definitely help alot of people as these 64 bit operating systems become more & more popular.
    -Bill
    Dec 2005
    214
    Bill,this is what I did and worked great
    7. install drivers
    Advanced Tuner Atomic's Avatar
    Jun 2008
    455
    I still have to do the F8, disable driver signature every time I restart or the drivers wont work.
    HP Tuners Support
    (foff667)
    28,262
    Did either of you guys try the exe file by any chance?
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    There are 2 ways to disable digital driver signature enforcement; the 1st way is using command-line tool cmd.exe to execute this command-line bcdedit.exe /set nointegritychecks ON , the 2nd method which is recommended is to diable it through Group Policy Object (GPO),
    1. Start --->> Run ---> GPEdit.msc
    2. Enable and Ignore Code signing for drivers policy under User Configuration --->>
    Administrative Templates ---->> System ---->> Driver Installation --->> Code signing for drivers
    try that...
    -Scott -
    Jun 2008
    455
    Quote Originally Posted by soundengineer View Post
    try that...
    Tried both of those, and neither work.
    Quote Originally Posted by Bill
    Yes, didnt work either.
    The problem is several updates from microsoft make these attempts ineffective in disabling the mandatory driver signature. It seems the command line command doesnt work after SP1, and the group policy editor doesnt work after some K****** updates.
    In trying to get the drivers to work without doing the F8 deal every time, I found out which ones, but cant recall at the moment. It shouldnt be too hard to find with google. We arent the only ones complaining about the mandatory driver signature in vista 64.
    Jul 2007
    320
    I mentioned this in another thread.. Solution for your F8 concerns
    http://citadel.x10hosting.com/readydriverplus/
    97 Grand Prix GTP (not going to bother listing mods in detail) 1 messed up 97 PCM with about 30-50% of a 2003 calibration and parts of a few others.
    Apr 2005
    4,387
    somebody just needs to make a driver hacker that allows you to add your own digital signature..or a driver wrapper that puts a signature in on it and allows the unsigned driver to run within the wrap
    somebody used to have one that worked for running old windows 98 stuff on xp when it first came out and the drivers didnt exist...I'm sure they could do it for vista
    -Scott -
    Mar 2009
    2
    Thanks a lot Bill. I tried it for the hundreth time and it worked!
    One quick question though.
    My computer is never off, i always leave it in hibernate mode, so does that mean i dont have to restart the computer and do the that pesky f8 thing anymore?
    Tuner in Training CjLink's Avatar
    Feb 2009
    Albuquerque, NM
    10
    i had some issues originally but after reinstalling the drivers i havnt had any issues...
    but for all i know dell only gave me the 32 bit incorrectly
    06 G6 GTP M6 3.9L LZ9 (pushrod V6 with VVT)
    Potential Tuner Turbo3.8L's Avatar
    Oct 2006
    Levittown Pa
    6
    I'm having trouble with mine and I'm computer stupid. I tried to install it twice, once auto and once manual. I'm going to try the exe file above in a couple of minutes.
    Oct 2006
    Levittown Pa
    6
    tried the exe way and it did not work for me. I uninstalled everything and did the F8method and got it to work. Kind of gay though now I need to do the F8 every time I want to use the cable.
    Dec 2005
    214
    Yes sir,still had to F8
    Mar 2009
    Kokomo,In
    54
    5. install drivers
    -Bill
    did this part of it and still get code 39
    Joe ''House'' Kupferschmid
    Diesel Tuning man..
    FB me or
    www.angoladavesdiesel.com
    Mar 2009
    Kokomo,In
    54
    Got it to work by doing the f8 trick!
    Diesel Tuning man..
    FB me or
    Mar 2009
    26
    any update on solving the mandatory f8?
    HP Tuners Support
    (foff667)
    28,262
    Quote Originally Posted by deenasty View Post
    No, hence the reason for this thread.
    Dec 2006
    Rockwall, Tx
    247
    Ive tried all of the options and I can not get the driver to work correctly. Lap top showed up yesterday and I think I have already worn out the F8 key.I get nothing from pushing it 100 times.
    Nevermind got it to work.
    Mar 2009
    3
    I try using F8 on start up and my computer does absolutely nothing but make sounds... No option to get around the digital sig on my computer... this sucks
    Dec 2008
    11
    i spent many hours trying to find a work around for the unsigned driver, but the only option that worked for me was the ftdi drivers.
    i think most people overlook the fact that they need to manually uninstall the hp tuners drivers, then install the ftdi drivers, and then connect the interface and manually install the drivers from the desktop.
    if anyone needs any help with this i am more than happy lend a hand. Just shoot me a pm
