Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 63
Thread: 64 bit vista guys that have gotten the drivers to work come in!
  1. #21
    Apr 2009
    13
    Quote Originally Posted by arcticbird45 View Post
    i spent many hours trying to find a work around for the unsigned driver, but the only option that worked for me was the ftdi drivers.
    i think most people overlook the fact that they need to manually uninstall the hp tuners drivers, then install the ftdi drivers, and then connect the interface and manually install the drivers from the desktop.
    if anyone needs any help with this i am more than happy lend a hand. Just shoot me a pm
    So how would you manually uninstall the hptuner drivers and install the ftdi drivers where they need to be also which ftdi drivers do you need?
  2. #22
    Advanced Tuner redhotjamedjimi's Avatar
    Dec 2006
    Philadelphia, PA
    352
    Yea i have had no luck with this 64bit stuff. It worked fine until repairs now it is my enemy so ill dual booting good ol xp on an extra drive. If anyone has a "for sure" way to use 64 bit ultimate to work PM me. Thanks.
    2006 SS Cobalt SC
    Stage 2 ZZP Cams
    Headers, 3.0" Full ZZP Exhaust
    60lb inj. Intake.
    2.8 Pulley
    72# Lb. Supertech Springs
    LNF Ext Valves and lashers
    Cobre H/E, option B.
    Torque Damper
    HPTuned.
    Bitchin'
  3. #23
    Apr 2009
    13
    Didnt the f8 thing work?
  4. #24
    Apr 2009
    Fulshear, TX
    12
    You should be able to create a signed driver by following this guide:
    http://www.minasi.com/newsletters/nws0903.htm
    Once the driver is signed you will have to import the certificate on your machine that matches the driver. Unless HPTuners wants to purchase a priv/shared certificate that someone can use.
    If I have some time I'll try to get this done, but I'll be pretty busy the next couple of weeks.
  5. #25
    Tuner RooTBeeR's Avatar
    Feb 2009
    Chino, Ca
    106
    Quote Originally Posted by fuseone View Post
    i'm wondering the same thing
    i have it so that the F8 will work, but i'd rather not have to do that ever time.
    Caution:Slow Learner
  6. #26
    Dec 2008
    on the Dyno
    1,825
    Bill I used the direct link I posted in a couple of the other threads to install the drivers onto my computer. But before you install these drivers using the *.EXE file you MUST uninstall the drivers you currently are trying to use. Then run the *.EXE file and then go about installing the suite like normal. It has worked on my computer and I didn't do any F8 trick's or disable any digital driver signing to make it work.
    I currently run this software on 3 different laptops and I am currently using a HP Mini running XP sp3... When I can get back to my other computer that runs Vista 64-bit I will completely unistall everything and try to make a video tutorial of installing the drivers and then the software. May take a few weeks to make where I'm pretty busy these upcoming couple weeks.
    Located in Central Kentucky
    ShorTuning
  7. #27
    Apr 2009
    13
    yea a video of it would be the best bet.
  8. #28
    Advanced Tuner TXZ0603's Avatar
    Dec 2007
    Houston, Tx
    375
    Finally
    2003 Z06
    Forged 347
    PTE Billet 67/65 Turbos
    FMIC / Dual 50mm Tial BOV's
    ID 1000 Injectors
    RSI Stage 4 Fuel System
    07 Z06 Cam
    Tripple Nozzle Meth
    ACT Twin disk clutch
    25# Boost
  9. #29
    Dec 2007
    Houston, Tx
    375
    well fark! it only works with the f8 when it want to! is there anything else to get this stuff to work? Need to tune my car.
    2003 Z06
    Forged 347
    ID 1000 Injectors
    07 Z06 Cam
    Tripple Nozzle Meth
    25# Boost
  10. #30
    Dec 2008
    on the Dyno
    1,825
    Sorry still no luck on the video... my fiancee' has pretty much taken the new laptop and called dibs on it so I rarely ever get on it. I know alot of people are still having issues even with the exe file that I linked. What you must do is make sure that all drivers are deleted. I've had usb->serial drivers like ftdi.sys really screw with my hptuners drivers as well so keep that in mind as well. If you try the method I posted above and it still doesnt work then you will need to find the location that the .exe file installs the drivers and manually select that driver location and install the cable drivers from there.
    ShorTuning
  11. #31
    Feb 2007
    San Antonio, TX
    1,255
    What exactly do we need IN the video? If its just a walk thru of the (2) methods on the threads previous page (1) instructions I can do that tonight. Even the whole unistall drivers option mentioned by LSxpwrdZ can be included. Anyone have hosting space for it?
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
  12. #32
    Jun 2009
    Avondale, AZ
    1
    i just purchased an asus laptop, on startup did f8 and it brought me to a screen that had load safe mode, etc. On the bottom it said load drivers without digital certificates. I selected that loaded the driver and no issue's so far.
  13. #33
    Feb 2007
    San Antonio, TX
    1,255
    Thumbs up
    Quote Originally Posted by Ruckus99ss View Post
    I did the same several times. No issues. F8 FTW!
    Now i have to set aside time to use Cam Studio to get a walk thru video up here...sometime?
    Janky Monkey Tuning
    Cell 210-954-4985
  14. #34
    Dec 2007
    Houston, Tx
    375
    well f8 wont even work for me now. dont know why but I have ZERO acces to my car through hptuners. Is there a definitive fix for this or do i need to sell my new laptop and buy another new laptop just to run this? How do you manually uninstall drivers? where are they located??
    2003 Z06
    Forged 347
    ID 1000 Injectors
    07 Z06 Cam
    Tripple Nozzle Meth
    25# Boost
  15. #35
    Feb 2007
    San Antonio, TX
    1,255
    Quote Originally Posted by TXZ0603 View Post
    My computer > Properties > Device Manager > HP Tuners HPVI A/B (Right click on the driver with an yellow ! on it and click unistall.
    Start over the installation process.
    Janky Monkey Tuning
    Cell 210-954-4985
  16. #36
    Dec 2007
    Houston, Tx
    375
    Thanks Bro!!!!!
    That worked most excellent
    2003 Z06
    Forged 347
    ID 1000 Injectors
    07 Z06 Cam
    Tripple Nozzle Meth
    25# Boost
  17. #37
    Tuner Twitch's Avatar
    May 2009
    NYC
    54
    So is everyone still doing the F8 thing?
    My current laptop wont charge the battery. I thought about buying a new 10", but if you guys are still having problems, I'll just put a new motherboard in this one.
    Tony
    05 CTS-V l LS6 l Maggie l Magnaflow Cat-back l Meth l 439rwhp/414rwtq
  18. #38
    Tuner in Training Kingsize's Avatar
    Jul 2007
    Baytown, Texas
    16
    Thank you for this post. F8 worked great, spent over 2 hours jacking with this. Is Windows 7 going to be this hard? My laptop is getting ready to go out to pasture and I hope it is not hard on the next gen OS. HP Tuners needs to play a little catch up on Windows OS vs: software compatibility.
  19. #39
    Feb 2007
    San Antonio, TX
    1,255
    My windows 7 beta edition required the same methods so far.
    Janky Monkey Tuning
    Cell 210-954-4985
  20. #40
    Jul 2009
    6
    I read some where that we can create a .bat (batch) to automaticly do the F8 & Turn Off Function at every start up.
    I have been researching this every day but i dont know how to write the .bat file to do such.
