Results 1 to 3 of 3
Thread: 2008 Jeep JK 3.8 Sprintex
    Mar 2023
    Since I didn't see anything here for this, figured I'd share this.
    2008 Jeep JK 3.8L with Sprintex Supercharger
    This is the tune loaded from a Diablo Tuner with Sprintex Tune, then read back off ECU with HP Tuners.
    2008JK_Sprintex00.hpt
    Can't buy this supercharger kit new anymore for 2007-2011 3.8L Jeep JK
    So had to find used one, then find all the correct parts that where missing.
    Mar 2023
    Here is parts list from Sprintex JK 3.8 Packing List.pdf
    Injectors are Bosch #
    stock are 0280158119, 21lb/hr)
    Sprintex Kit requires 0280158193 30.7lb/hr
    Requires a 2bar SRT MAP sensor 05033224AB
    I'm still trying to figure out what Boost bypass valve actuator I can use as a replacement. Maybe something adjustable.
    Think maybe diaphram is leaking. Getting a strange surging at between 0 - 7 inHg. and only seeing about 3psi boost, would like to see 5psi.
    Dec 2006
    Birmingham, Alabama
    156
    you need to turn Baro Leanring off.
