For some reason, my car keeps wanting to pull a flat 18 degrees of timing at WOT through the entire RPM range... This is a problem for me at 13-14lbs of boost w/ no intercooler. Nowhere in my bin file do I have it set for even CLOSE to that amount of timing at those RPMs/Cylinder Airs... It should be like 9-10degrees ala high octane table. Car is a 99 GTP w/ lots of goodies that are besides the point. Any ideas or pointers? I looked back at some older logs I had and noticed that they were running 18 degrees of advance from 70-130 MPH at WOT. Wasnt a problem then because it was 18 degrees outside and I was only running ~12psi, not 40 degrees and ~14psi
HELP ME!!!
Tim
PS, me just started to remember.. Doesnt the ESC modules have some kind of limp mode or fallback timing. Does HPT read a commanded timing, or timing being issued by the ESC module. Keith? Chris?
