Would like to see function to do fuel injector balance test. I think this is a function on the Tech 2. hook up a fuel pressure gauge, prime pump, then pulse injector for a set period of time. write down fuel pressure before and after for all 8 injectors, then compare the differences.
Is this somthing that can be added? This would be a key on engine off test. The tech 2 limits you to only pulsing each injector one cycle unless you start the engine...to prevent flooding.
