I've been trying to figure this out forever. I've read so many formulas for correctly sizing the injectors for the IFR table and now I don't know what's right. I've upgraded to lucas 42.5lb injectors btw. Anyways, the formula I'll be trying now will be 42.5/22=1.931818etc.. Then multiplying my stock table by that.
The other formula "([Rated Flow]*Sqrt[(vacuum+fuel_pressure)/rated pressure] = flow rate" Got me all lost because I don't know any of the information that's needed to plug into it.
I've read the injector spread sheet and tried that in the v6 tab but it doesn't make sense to me.. The numbers it told me to plug in started at like 5.3 so I knew that wouldn't work out.
But I had read somewhere recently in this forum that since I'm using a vacuum referenced FPR I should have a flat IFR at 42.5 straight across the board. How much truth does that hold?
I want to get these injectors out of the way so I can get to MAF and VE tuning but I feel as if I've hit a brick wall. How can I even tell if I've gotten my injectors tuned in correctly?
I'm running a turbo with 7-9lbs of boost so from what I've read I want to keep my FPR's vacuum reference line still connected and not have a flat IFR. Help?
