Results 1 to 3 of 3
Thread: please , help me !
    Aug 2008
    Saudi Arabia, Riyadh
    37
    please , help me !
    what is mean this code :
    p1626-Theft Deterrent Fuel Enable signal Not Received .
    this code is come with this code :
    [PCM] P1336 - Crankshaft Position (CKP) System Variation Not Learned (SES) (Pending) (Old) (History) (Current) (Immature)
    thank ...
    Generally receive that code when you have a VATS issue, using a PCM where the VATS hasn't been relinked or someone has been dicking with the PCM and written an entire file and therefore VIN to something non original.
    Try a VATS are-link and that should solve the P1626. The P1336 seems immature, so try the relink first and see if it goes away otherwise I am suspecting that you are working on some sort of project donor car where the engine/PCM is not in its original car and you *may* need a to perform a CASE learn or there may be an issue with wiring/crank sensor itself but wouldn't be the first thing I'd check.
    Aug 2008
    37
    Thank you ( SSUte01 ) very much >>
