Results 1 to 8 of 8
Thread: Looking for 95 Chevy Tahoe Codes
    Apr 2003
    2
    Anyone have codes for a 95 Chevy Tahoe??
    PCM-16197427 Prom-BJYK
    I'm new at PCM hacking so I'm also looking for a starting place...
    I have the ALDL interface built and tested and have had some responses, just not sure where to start or decode...
    Thanks. Mike
    Dec 2002
    27
    Re: Looking for 95 Chevy Tahoe Codes
    DATA STREAM A217 SPECIFICATION
    ..PAGE
    SPECIFICATIONS FOR DATA STREAM INFORMATION
    PCM-6 WITH 4L60E TRANSMISSION
    ENGINE USAGE:
    L03 TBI 5.0L 94 VIN = H C,K,G
    L05 TBI 5.7L 94 VIN = K C,K,G
    L35 CPI 4.3L 94 VIN = W S,T,M,L
    LB4 TBI 4.3L 94 VIN = Z G,M,L,S,T,C,K
    LB4 TBI 4.3L 94 VIN = Z C,K MANUAL TRANS.
    * L03 TBI 5.0L 95 VIN=H C,K,G
    * L05 TBI 5.7L 95 VIN=K C,K,G
    * L35 CPI 4.3L 95 VIN=W S,T,M,L
    * LB4 TBI 4.3L 95 VIN=Z G,M,L,S,T,C,K
    DATA PIN : READ DATA ON PIN "M" OF ALDL CONNECTOR
    BAUD RATE : 8192 BAUD - BI-DIRECTIONAL
    ..PAGE
    MODE 0 (RETURN TO NORMAL MODE)
    ALDL REQUEST:
    - MESSAGE ID = $F4
    - MESSAGE LENGTH = $56
    - MODE = $00
    - SUM CHECK
    THE PCM WILL RESPOND WITH THE FOLLOWING MESSAGE:
    - MESSAGE ID = $F4
    - MODE = $00
    - SUM CHECK
    MODE 1 (TRANSMIT FIXED DATA STREAM)
    ALDL REQUEST:
    - MESSAGE ID = $F4
    - MESSAGE LENGTH = $57
    - MODE = $01
    - MESSAGE = $00
    - SUM CHECK
    - MESSAGE ID = $F4
    - MESSAGE LENGTH = $95
    - MODE = $01
    - DATA BYTE 1
    - DATA BYTE 63
    - SUM CHECK
    MODE 10 (CLEAR MALFUNCTION CODES)
    ALDL REQUEST:
    - MESSAGE ID = $F4
    - MODE = $0A
    - CHECKSUM
    - MESSAGE ID = $F4
    - MODE = $0A
    - SUM CHECK
    ..PAGE
    ..HEAD02L ALDL DATA LIST
    ..HEAD03L NUMBER OF DATA WORDS - 63
    ..HEAD04L ALDL MODE 1 DATA LIST
    WORD # DATA NAME DESCRIPTION
    1 PROMIDA FIRST PROM I.D. WORD (MSB)
    2 PROMIDA+1 SECOND PROM I.D. WORD (LSB)
    ID = N
    3 NVMW NON-VOLITALE MODE WORD
    0 02 SENSOR READY FLAG 1 = READY
    1 CLOSED LOOP TIMER O.K. FLAG 1 = TIMER O.K.
    2 1 = RAM REFRESH ERROR HAS OCCURRED
    3 IMPROPER SHUTDOWN FLAG 1 = IMPRO 0 = PROPER
    4 HOT RESTART PROCEEDING FLAG
    5 NOT USED
    6 NOT USED
    7 MALF 42 FAIL FLAG (EST. MONITOR)
    4 DIACMW3 MODE WORD FOR IDLE CONTROL
    0 1 = A/C ON
    1 1 = DRIVE 0 = P/N
    2 1 = CONDITIONS FOR C/L ON RPM HAVE BEEN MET
    CONDITIONS ARE TPS CLOSED AND LOW MPH.
    3 1 = C/L ON RPM ENABLED
    CONDITIONS MET LONG ENOUGH OR LOW RPM ON A/T VEH.
    4 1 = STALL SAVER
    5 1 = POWER STEERING PRESSURE LOAD ACTIVE
    6 1 = THROTTLE KICKER HAS BEEN DISABLED ONCE
    7 1 = IDLE RPM TO HIGH (SIGN)
    5 ISSPMP IAC PRESENT MOTOR POSITION
    N = IAC MOTOR STEPS
    Dec 2002
    27
    6 MALFFLG1 MALF FLAG WORD 1
    0 CODE 21 THROTTLE POSITION HIGH
    1 CODE 19 NOT USED
    2 CODE 18 NOT USED
    3 CODE 17 NOT USED
    4 CODE 16 2002 PPM VEH. SPEED SENSOR FAILURE
    5 CODE 15 COOLANT SENSOR LOW TEMPERATURE
    6 CODE 14 COOLANT SENSOR HIGH TEMPERATURE
    7 CODE 13 OXYGEN SENSOR
    7 MALFFLG2 MALF FLAG WORD 2
    0 CODE 29 NOT USED
    1 CODE 28 PRESSURE SWITCH MANIFOLD
    2 CODE 27 NOT USED
    3 CODE 26 NOT USED
    4 CODE 25 MAT SENSOR HIGH
    5 CODE 24 VEHICLE SPEED SENSOR
    6 CODE 23 MAT SENSOR LOW
    7 CODE 22 THROTTLE POSITION LOW
    8 MALFFLG3 MALF FLAG WORD 3
    0 CODE 38 BRAKE OFF
    1 CODE 37 BRAKE ON
    2 CODE 36 IAC THROTTLE KICKER FAILURE
    3 CODE 35 IAC FAILURE
    4 CODE 34 MAP SENSOR LOW
    5 CODE 33 MAP SENSOR HIGH
    6 CODE 32 EGR FAILURE
    7 CODE 31 GOVERNOR FAILURE
    9 MALFFLG4 MALF FLAG WORD 4
    0 CODE 47 NOT USED
    1 CODE 46 VATS FAILURE
    2 CODE 45 OXYGEN SENSOR RICH
    3 CODE 44 OXYGEN SENSOR LEAN
    4 CODE 43 ESC FAILURE
    5 CODE 42 EST. MONITOR
    6 CODE 41 1X (CAM PULSE) SENSOR FAILURE
    7 CODE 39 TCC OFF
    10 MALFFLG5 MALF FLAG WORD 5
    0 CODE 56 NOT USED
    1 CODE 55 ADU ERROR
    2 CODE 54 FUEL PUMP RELAY MALFUNCTION
    3 CODE 53 SYSTEM VOLTAGE HIGH
    4 CODE 52 SYSTEM VOLTAGE HIGH-LONG TEST
    5 CODE 51 PROM ERROR
    6 CODE 49 NOT USED
    7 CODE 48 NOT USED
    11 ISDSMP IAC DESIRED MOTOR POSITION
    N = IAC MOTOR STEPS
    12 DIACMW1 IDLE AIR CONTROL NV MODE WORD
    0 1 = MOTOR RESET IN PROGRESS
    1 FIRST DRIVEAWAY FLAG FOR IAC KICKDOWN LOGIC
    1 = IACV COLD OFFSET HAS BEEN KICKED DOWN THIS START
    2 0 = RESET REQUESTED
    3 NOT USED
    4 1 = A STABLE IDLE WITH WARM ENGINE HAS OCCURRED THIS RUN
    CYCLE - A/C OFF IN DRIVE
    5 1 = A STABLE IDLE WITH WARM ENGINE HAS OCCURRED THIS RUN
    CYCLE - A/C ON IN DRIVE
    6 1 = FIRST PASS OF MALF 36 HAS FAILED
    7 NOT USED
    13 DIACMW2 IDLE AIR CONTROL NV MODE WORD
    0 MOTOR DIRECTION 1=EXTEND 0=RETRACT
    1 NOT USED
    2 COIL A STATE
    3 COIL B STATE
    4 STEPPER MOTOR ON/OFF STATUS 1=ON 0=OFF
    5 NOT USED
    6 NOT USED
    7 NOT USED
    14 DIACMW4 MODE WORD FOR IDLE CONTROL
    0 1 = ETC ONCE FLAG
    1= SPECIAL IACV OPEN LOOP COLD ENG MODIFIERS ARE DISABLE
    1 1 = ETC * K97_EDP
    2 1 = THROTTLE KICKER ACTIVE
    3 1 = THROTTLE KICKER DISABLE REQUESTED
    4 1 = THROTTLE KICKER BARO DISABLE REQUEST
    5 1 = PART 2 OF DIAGNOSTIC TEST TO BE
    Dec 2002
    27
    6 1 = PROP LIMITING AUTHORITY BEING EXERCISED
    7 1 = ADD DERIVATIVE TERM TO GPSFLOW
    0 = SUBTRACT DEVIVTIVE TERM FROM GPSFLOW
    15 COOLDEGA NORMALIZED ENGINE TEMPERATURE nondefaulted
    DEGREES C = .75N - 40
    DEGREES F = 1.35N - 40
    16 ADBAT BATTERY VOLTAGE A/D VALUE
    VOLTAGE = N/10
    17 ADTHROT THROTTLE POSITION A/D VALUE
    VOLTS = N*5/256
    18 ADMAP MANIFOLD PRESSURE A/D VALUE (updated in 100ms loop)
    VOLTS = N*5/256
    kpa = (N + 28.06)/2.71
    19 ADO2A OXYGEN SENSOR VARIABLE
    mV = 4.42N
    20 MWAF AIR FUEL MODE WORD
    0 PE DELAY TIME COMPLETE FLAG
    1 1 = VATS FREQUENCY TEST PASSED
    2 BL. ADDRESS CHANGE FLAG 1=CHANGE
    3 DELAY BLM UPDATE 1=BL ADDR CHANGE
    4 DE FLAG 1=DE IS ACTIVE
    5 PE FLAG 1=PE IS ACTIVE
    6 AE FLAG 1=AE IS ACTIVE
    7 DELIVER ASYNCH. PULSE FLAG
    21 SDMW SERIAL DATA MODE WORD
    0 1 = IN MODE 10 OF ALDL (MESSAGE ID=$F5)
    1 1 = IN MODE 10 OF ALDL (MESSAGE ID=$F4)
    2 1 = TRANSMISSION DIAGNOSTICS DISABLED
    3 NOT USED
    4 NOT USED
    5 1 = TRANSMIT OVERRUN HAS OCCURRED
    6 1 = TRANSMISSION IN PROGRESS
    7 1 = SECOND BYTRE TRANSMISSION PENDING
    22 MWBG MINOR LOOP MODE FLAG
    0 FACTORY TEST ENTERED
    1 AE CLAMP FLAG 1=CLAMP IS ACTIVE
    2 SKIP MALF 42 DUE TO ALDL
    3 1st REF FLAG 1=REFERENCE PERIOD
    4 1=IGNITION OFF
    5 1=HIGH MAT CONDITIONS OBSERVED
    6 FIRST GOOD M42A FLAG
    7 LOCK-IN MALF 42A 1=LOCKED IN
    23 MW1 MINOR MODE WORD 1
    0 ADVANCE FLAG 0=ADV. 1=RETARD
    1 CHECK ENGINE LIGHT DELAY FLAG
    2 LOOP RAN OVER 6.25 MSEC
    3 OPEN TPS VE FLAG 1=OPEN
    4 RUN FUEL FLAG 1=RUNNING
    5 VE INT RESET FLAG 1=RESET
    6 MAJOR LOOP EST MONITOR ENABLE
    7 ENGINE RUNNING FLAG 1=RUNNING
    24 MW2 MINOR LOOP MODE WORD 2
    0 SYNCHRONOUS MAP SENSOR READS IN EFFECT
    1 O/L IDLE FLAG FOR AIR SWITCH ENGAGE
    Dec 2002
    27
    AT IDLE
    2 REFERENCE PULSE OCCURRED
    3 1 = DIAGNOSTIC SWITCH IN FACTORY TEST POSITION
    4 1 = DIAGNOSTIC SWITCH IN DIAGNOSTIC POSITION
    5 1 = REF PULSE HAS OCCURRED
    6 1 = IDLE SPARK ENABLED
    7 IDLE FLAG
    25 IODPORTC I/O PORT C
    0 1 = A/C REQUEST
    1 1 = BRAKE SWITCH (1=BRAKE PRESSED)
    2 RANGE 1 SEE PRNDL TABLE
    3 RANGE 2 SEE PRNDL TABLE
    4 RANGE 3 SEE PRNDL TABLE
    5 NOT USED
    6 NOT USED
    7 FOUR WHEEL DRIVE LOW 1=ON
    PRNDL TABLE:
    RANGE1 RANGE2 RANGE3 GEAR
    0 1 1 LOW
    1 1 1 DRIVE2
    1 1 0 DRIVE3
    1 0 0 DRIVE4
    1 0 1 P/N
    0 0 1 REVERSE
    26 CLCCMW MAJOR LOOP MODE WORD 1
    0 SYNCHRONOUS AE FLAG 1=SYNCH AE
    1 SLOW RICH/LEAN FLAG 1=RICH
    2 AIR MANAGEMENT ON 1=ON
    3 DECEL FUEL CUT-OFF FLAG 1=DFCO
    4 1 = OVERSPEED FUEL SHUTOFF
    5 DFCO IAC FAST FILTERED FLAG
    6 1 = N.V. MEMORY BOMBED
    7 1 = HAS BEEN IN C.L AT LEAST ONCE SINCE RESTART
    27 ADBARO RAW A/D COUNTS FOR BARO FILT IN TRANS
    VOLTS = N*5/256
    28 LCCPMW TCC & A/C MODE WORD
    0 NOT USED
    1 1 = SPK. CORRECTION DUE TO MAT IS NEGATIVE
    2 NOT USED
    3 1 = A/C AE ENABLED
    4 ACPSCT FLAG (A/C ON)
    5 PARK/NEUTRAL (use range 1,2,3 to determine p/n status)
    6 NOT USED
    7 1 = CCP SOLENOID ENERGIZED
    29 MWAF1 AIR FUEL MODE WORD 1
    0 DFCO TPS AE FLAG
    1 LEARN CONTROL ENABLE FLAG 1=ENABLE
    2 1 = LOW BATTERY
    3 A/F DECAY INT DONE FLAG FOR COLD PRK TO DRIVE
    4 ASYNCHRONOUS PULSE FLAG (AP FLAG)
    5 CLOSED LOOP FOR O/L IDLE CONDITION
    6 RICH-LEAN FLAG 1=RICH 0=LEAN
    7 CLOSED LOOP FLAG 1=CLOSED
    30 TCCMODE TCC MODE WORD FLAGS
    0 1 = TCC IS BEING FORCED OFF
    1 1 = TCC ENABLE SOLENOID VALID
    2 1 = LOW THRESHOLD FOR COPETCC SELECTED
    3 1 = USE HYST FOR VEH. SPD.
    4 1 = TCC IS IN RELEASE MODE SLIPPING
    5 1 = TCC IS IN LOCK-ADJUST MODE
    6 1 = TCC IS BEING APPLIED
    7 1 = NEGATIVE SLIP RECENTLY PREVENTS APPLY
    31 FILTMPH FILTERED MPH VARIABLE
    MPH = N
    KPH = 1.61N
    32 IODPORTB SOLENOID COMBINATION FOR
    Dec 2002
    27
    DIGITAL EGR
    0 SHIFT A SEE TABLE
    1 SHIFT B SEE TABLE
    2 IAC COIL A
    3 IAC COIL B
    4 IAC ENABLE 1=ENABLE
    5 FORCE MOTOR ENABLE 1=ENABLE
    6 REF IRQ CLR
    7 M/CLR
    SHIFT B SHIFT A GEAR
    0 0 3RD
    0 1 4TH
    1 0 2ND
    1 1 1ST
    33 PPSWVLT BATTERY VOLTAGE FROM PPSW A/D COUNTS
    VOLTS = N/10
    34 NTRPMX RPM VARIABLE USED FOR TABLE F1 EXTENSION LOGIC
    RPM = N * 25
    35 OLDRFPER LAST MINOR LOOP REFERENCE PERIOD FROM ECU (MSB)
    36 OLDRFPER+1 LAST MINOR LOOP REFERENCE PERIOD FROM ECU (LSB)
    MSEC = N/65.536
    RPM = 65.536* # OF CYLINDER/N
    6 CYL = 20 8 CYL = 15
    37 EGRDC EGR DUTY CYCLE
    % = N/2.56
    38 MW3 MISCELLANEOUS MODE WORD
    0 CPI/PFI SINGLE FIRE FLAG 1=SINGLE FIRE
    1 SINGLE FIRE FIRST TIME 1=FIRST TIME
    2 REFRESH RAM IN BACK GROUND 1=YES
    3 1 = POWERDOWN IN PROGRESS
    4 1 = HIGH BATTERY VOLTAGE
    5 DFCO SPARK FILTER FLAG
    6 START-UP SPARK FILTER DONE FLAG 1 = DONE
    7 TRANSITION FLAG 1=TRANSITION ACTIVE
    39 TIMEENG ENGINE RUNNING TIME,SECONDS (MSB)
    40 TIMEENG+1 ENGINE RUNNING TIME,SECONDS (LSB)
    SECONDS = N
    41 DESSPD DESIRED IDLE RPM
    RPM = 12.5N
    42 NDTHRPOS THROTTLE POSITION FOR ENGINE
    % = N/2.56
    43 MW4 MODE WORD 4
    0 1 = HIGH ESC ACTIVITY FLAG
    1 1 = ZERO ACTIVITY FLAG
    2 BLOCK LEARN CLOSED THROTTLE POSITION FLAG 1=THROT CLOSED
    3 1 = VARIABLE TUNING CONTROL
    Dec 2002
    27
    ENABLED
    4 1 = A/C DISABLED DUE TO HIGH RPM
    5 1 = A/C ANTICIPATED TO BE ON
    6 1 = CONVERTER OVERTEMP DETECTED
    7 1 = QUASI CLOSED LOOP ENABLED
    44 MW5 MODE WORD 5
    0 1 = ACTUAL ENGINE SPEED OVER DESIRED SPEED
    1 1 = DELATCH ACTIVE
    2 1 = SHIFT LIGHT ON
    3 1 = HIGH RPM INDICATED BY TRANS. ABUSE LOGIC
    4 1 = POWER STEERING CRAMP SAG/STALL SAVER ACTIVE
    5 1 = A-INJECTORS FIRED AT FIRST REF. PULSE FLAG
    6 1 = SINGLE FIRE ALT EXIT IS DESIRED
    7 NOT USED
    45 SAREFFNL FINAL VALUE OF SAREF(MSB)
    46 SAREFFNL FINAL VALUE OF SAREF(LSB)
    DEGREES = N*90/256
    47 PA2OLD ECU PA2 COUNTER VALUE FROM LAST MINOR LOOP(MSB)
    N = COUNTS
    48 PA2OLD+1 ECU PA2 COUNTER VALUE FROM LAST MINOR LOOP(LSB) NOT USED
    49 INT CLOSED LOOP INTEGRATOR VALUE
    N = INTEGRATOR COUNTS
    50 DESTPS DESIRED GOVERNING TPS VALUE TO BE OUTPUT
    % = N/2.56
    51 ALDLCNTR ALDL RICH/LEAN CHANGE COUNTER
    N = COUNTS
    52 LEGRMW EGR & SPARK MODE WORD
    0 EGR DIAG INT RESET FLAG
    1 1 = BURST KNOCK RETARD ACTIVE
    2 EGR HI VAC HYST FLAG
    3 AE FIRST TIME FLAG
    4 EGR MAP HYST FLAG
    5 EGR TPS HYST FLAG
    6 EGR MPH HYST FLAG
    7 EGR ON CONDITION
    53 GOVMW ELECTONIC GOVERNOR MODE WORD
    0 1 = CURRENTLY IN RPM GOVERNING MODE
    1 1 = GOV LEAD MODE ANTICIPATING RPM GOVERNING
    2 RPM OVERSPEED FLAG 1 = RPM OVERSPEED
    3 GOVERNOR OVER SPEED LIGHT ON
    4 1 = RPM LEAD TPS RETURN MODE
    5 NOT USED
    6 MPH OVERSPEED FLAG 1 = MPH OVERSPEED
    7 1 = CURRENTLY IN MPH GOVERNING MODE
    54 BLMCELL BLOCK LEARN MULTIPLIER CELL
    N = BLOCK LEARN CELL
    55 BLM BLOCK LEARN MULTIPLIER
    N = MULTIPLIER
    56 NOCKRTD KNOCK RETARD
    DEGREES = 45N/256
    57 BPW BASE PULSE WIDTH(MSB)
    58 BPW+1 BASE PULSE WIDTH(LSB)
    mSEC = N/65.536
    59 DSEGRPOS DESIRED EGR COMMAND
    % = N/2.56
    60 ACEGRPOS LINEAR EGR ACTUAL PINTLE POSITION
    % = N/2.56
    61 ADEGRP LINEAR EGR PINTLE POSITION RAW A/D COUNTS
    N = EGR POSITION A/D COUNTS
    62 PURGEDC PURGE DUTY CYCLE VALUE
    % = N/2.56
    63 MATDEGA NON DEFAULTED MAT
    now my head REALLY hurts! ;D
    where did you find that info? Hopefully not a top secret source..lol
    Business Network Solutions - for all your PC, network, printer and computer security needs.
